Hey George,
Are the bosch colt mounts done? When you
can ship tabletop and the rest i've paid for already??
I've emailed you numerous times in the past week and half with no response...please reply.
Jeff
Cool. Please link them here also.
Hey George,
Jeff
I don't know where your emailing ? i never got one email, last email i got was you telling me your going to wait for mount before table top to be send , i told you last email i just send top now and mount when there done?
XZero cnc
Hi Everyone , there is no more of the supported rails machines for sale to new customers, i only have left for people that got already and will not be making more machines
XZero cnc
The reason I am not making the supported round rail machine no more is the length of time to put together.
Every machine has always been different when setting them up, and take so much time to get everyone to work proper.
It is the strongest of all the machines, but takes 30x longer to get right.
The machine has been back luck for me from the start, rushed design, changes, parts, mistakes ,hard to reassemble without not damaging the bearings ,
To work on a machine for 7 straight days on one machine to get all right, then sending machine out not completely paid off
and getting only 1000 for all your time plus machine and shipping ,because people waiting long for them and just sent them out thinking there like me and pay their debts .
I still think the supported machines is the best of all of them , but one wrong thing will totally make it a nightmare , just one tighten wrong screw will do it and take forever to find the problem.
At this time just trying to get out the supported machines is just back everything up to a stop over and over again.
Spent so much time to get the machine to be the best , and not reassemble right after is now causing problems and blame the machine,
So it is better just to stop it and maybe bad luck will stop,
XZero cnc
And also perhaps this will speed up the leadtime on the square rail machines. It should hopefully be easier for you now.
....it really is a shame that people have not paid. Not everyone out there is that way George and you should try not to let them poison your perception of mankind in general......HOWEVER, I would never have sent a machine out without payment because I tend to distrust people. Kudos to you for at least trusting your fellow man, sorry you got burnt. :-(
Any idea as to when you expect the replacement ballscrews for the 40 x 60 machines.
this machinist thing is alot of work!
after alot fo trial and error - mostly with jigs, i have arived at these:
yay!
theres a few "issues" with georges machine that i had to watch out for though.
1st is obvious, the machine is light, and when you push hard it flexes. so i had to find the right balance of fedd rate and depth. that said, it plows through wood with relative ease when you get it all dialed in. most of my cuts are 1/4" depth, 50-75% tool width, and 200ish ipm. i slow it down to 75ipm on some finish passes, as im using a super long 1/4" end mill thats got its own flex issues. i ran the top carving with a 1" ball nose at 350ipm (the fastest i trust the machine not to stall at right now). plunging is a general nono (and is kinda on most machines) as it flexes back the spindle and casues the bit to not be perpendicular to the work. so instead a slower feed rate ramp or helix is best to enter the work piece. youll always want a fine finish pass on side walls that are critical, as well as bottoms of pockets.
second issue is a strange one thats harder to find a work around. the linear rails butt up against the uprights and end plates. wood dust collects in the corners and you effectively loose more and more travel - up to about 1/4" on each end if you arent paying attention. unfortunately putting a bellows on is not viable, because that will eat alot more travel. i think the best bet is to simply not have the dust reach there by using a vacuum hood. i happen to be using all the y travel with only 1/8" to spare each end, so i need to do something.
anyhow, i took many pictures of my program stages and jig, im going to organise them into their own thread later. will probably do a video soon, but ive run out of wood sized for these bodies, haha.
Nice work....
What size machine is it and what motors and drivers and spindle are you using. I am impressed with the feed rates you are able to get for a light weight machine.
sweet. that will be highly useful.
Also will be switching lots of the machines to the Bosch Rexroth aluminum profiles
XZero cnc
