XZero CNC - Page 4
Page 4 of 225 FirstFirst 12345671454104 ... LastLast
Results 61 to 80 of 4491
Thread: XZero CNC
  1. #61
    May 2010
    Default ViperX machine
    The ViperX machine with photos posted recently looks nice. Can you post the pricing for it please, and what sizes it's available in?
    Thanks!
    Dan
  2. #62
    Jun 2007
    canada
    Quote Originally Posted by dwolsten View Post
    Thanks!
    Dan
    you should email him for the price as it tends to fluctuate a little.
  3. #63
    Member gio666's Avatar
    May 2008
    New high pitch high speed ballnuts for 20mm turn screws
    XZero cnc
  4. #64
    Mar 2009
    Quote Originally Posted by gio666 View Post
    Would be nice to have these on my machine!
    Scott...
  5. #65
    May 2008
    Most of the time when i get the machining done overseas the always to big still , but was not worried about getting them redone , this time they didn't even machined close to the drawing and came far to short for the 40x wide machines
    XZero cnc
  6. #66
    May 2008
    Also can not post prices on the forum like other threads , i don't want to get another thread closed
    XZero cnc
  7. #67
    May 2008
    also will have 40x wide supported machine now, that the 30x wide has all problems redone , and working on a 48x wide in the square rails once these ones are gone and out
    XZero cnc
  8. #68
    May 2008
    Will have both 48x in a low machine like the 40x and also one made of steel frame
    XZero cnc
  9. #69
    Mar 2006
    George
    I dont see where you give an overall dimension of the length of the ballscrew? Do you specify somewhere the length of the ballscrew between machined ends? Just curious how one specs end machining on ballscrews.
  10. #70
    May 2008
    It is the same machining for all the ballscrews, the total length of the ballscrew includes the machining, so for 40x it would be 1003mm , and 24x would be 603mm total length with machining , they made the L2 with out adding the L3 in it , then added L3 after , making them around 10mm to short, no problem getting redone if to long , but to short there nothing can do , but the replacement ones should be here right away ,
    XZero cnc
  11. #71
    Dec 2009
    Exclamation Machining
    Is the quality of these ballscrews in the picture typical of what I should expect on my 40 x 60 ?
  12. #72
    May 2008
    what do you mean by quality?
    XZero cnc
  13. #73
    Dec 2009
    Smile Quality
    Your kidding right
  14. #74
    May 2008
    Quote Originally Posted by jwalker5 View Post
    Your kidding right
    NO , Quality of machining or Quality of ballscrews? The ballscrews are Taiwan made and just end machined in china ,
    XZero cnc
  15. #75
    Dec 2009
    Default Quality
    The quality of machining is the quality of the ballscrew! The pictures show rough threads like they were cut with a die, not machined and the shaft looks pitted. If these are superficial then fine, but if they represent the quality of workmanship, then I would be concerned. All we have to judge anything is a picture and questions.
  16. #76
    May 2008
    The ballscrew still have packing grease , dust , dust from surface grinding?on them , there not clean yet? i don't clean them till there going on machine?
    i took pictures like that because if there remove from there bag , the company won't credit the machining cost , and say there not their ballscrews, also they send right away new ones that way if its there fault , the line on the one ballscrew is to show how much they over machined?
    XZero cnc
  17. #77
    Dec 2009
    Default Ballscrews
    Perfect George. That is why I asked. The pictures are misleading and that puts my mind to rest.
    Now the next question is were these ballscrews in the picture for my machine and if so how long are we looking at to get these remade.
  18. #78
    May 2008
    the replacement for the 40x is on there way already , and other will be remachined to to fit next one down in size
    XZero cnc
  19. #79
    May 2008
    also the picture is 12x zoom , shot in super macro and a magnifying glass ,also had to use measuring tape as they don't believe digital calipers in pictures
    XZero cnc
  20. #80
    Jun 2007
    canada
    so im about to knock out some production guitar bodies with the hiwin router. ill be posting pics and such in a new thread in the music section over the weekend.
XZero  CNC
XZero  CNC
