Page 11 of 16 FirstFirst ... 891011121314 ... LastLast
Results 121 to 132 of 185
Thread: XYZ Gantry Build with Rotary Axis
  1. #121
    Jan 2005
    Bob,
    That is looking really nice. I am glad you are keeping the smoke where it belongs.
    Sorry for not keeping a closer eye on things. I am either missing or ignoring the update emails.
    Soon the real learning will happen.
    Thanks for all the pictures.
    Dave
  2. #122
    Jan 2007
    U.S.A.
    Thanks Dave
    I'm a connector or two away from connecting it to the computer and seeing about getting some initial movement.....
    ....however this moment is bittersweet. On one hand I'm REAL excited about getting some movement, on the other hand, I shoved everything in the garage to the outside to have room to build this thing. I've dissassembled my old machine and am trying hard to get rid of as much stuff as I can (painful as it is to through ANY scrap of wood away) not only to make room in the shop for the new toy, but I'm finally fed up having tools I don't have room to use and things I can't find.
    So....I've been cleaning the garage,err, shop. I really want to get things organized, but right now I'll be happy to decide where the big stuff goes and deal with the rest after the machine is set up.
    My trash collecors are hating me right about now
    Anyhow, it won't be long now
    BobL.
  3. #123
    Jan 2005
    Bob,
    Just checking in to see if you are still alive?
    So close but yet so far. ;-)
    Dave
  4. #124
    Apr 2011
    Like Dave,
    Hope all is ok
    Will
  • #125
    Jan 2007
    U.S.A.
    Still here...able to cut air :)
    Hey guys,
    Still here. Been a lot of life to contend with lately but have made some progress.
    The good news is I have been able to cut some air For the most part the control box checked out good. With all the opportunities for a crossed wire or something I was surprised that other than one loose connection things checked out ok.
    The bad news is I blew my last panel voltmeter. I haven't done much trouble shooting there but did discover that somehow I managed to forget to ground the 50v PS chassis. I don't know if this is whats causing the meters to blow. Two different digital voltmeters read the supply fine.
    The other thing is one of my motor couplers is the wrong size where it connects to the Y axis ballscrew. I had to wrap some .005" shim material around the shaft to mate the motor for checkout. I have not contacted XYZ about it yet, trying to decide if I need to remove the motor and mic out the shaft and coupler to supply this info to them.
    Currently working on the home switches. I am debating whether to even put any on the Z at this point.
    It looks like I might have this entire weekend in the shop, that will be great. Will post some pictures soon.
    BobL.
  • #126
    Jan 2007
    U.S.A.
    Gave birth to several hundred pounds of bouncing baby CNC !
    I know I haven't posted in a bit but progress has been made.
    There is a still alot of work to do but I once again have a functioal CNC machine. Man does it blow my old one away.
    It's nowhere near done and when I get tired of playing with it I'll get back to work on it I haven't even really set it up yet... But to catch up...
    I cleared out the spot where it will rest. Then I connected the motors and turned it on hoping the motors would lock. They did. I quickly set up some inputs and outputs and tried to get some movement. Gawd, the noise was horrendous. And the gantry racked. Movement was jerky.
    Long story short, I had two problems. One was a loose connection at the wire nuts I used just outside the control box. I left them there just knowing I was gonna get at least one wire crossed between all the connection points and connectors. But dang if they weren't all correct. Just a loose wire nut !!
    I forgot to check the straps internal to the Geko drives before I installed them. I deduced they were set to half step and have verified that. I set them to 10 micro steps but am not convinced I will leave them that way.
    Anyhow, after that movement was much better. I still need some motor tuning but hey, good enough to truck on.
    Next I leveled the machine with just a carpenters level. A good one at least though.
    I debated on how to attach the home switch on the gantry and ended up just screwing a bracket on the side. I also made some quick and easy magnet holders to trip the switches. I figured I'd worry about adjusting them later. (I had and idea to use an eccentric to adjust). Anyway, I initially just set the home magnet postions by using the lighted switches as a guide. Slide the magnet just until the switch tripped and tightened them down.
    Next I taped a piece of paper on the table and stuck a sharpie in the collet. I marked the four corners of a rectange on the paper at 22 x 34 inches. I took a steel rule and measured the diagonals. Dang if it wasn't but 1 millimeter off ! I loosened one magnet and gave it a tap. Tested again and once again it was 'close enough' to proceed.
    I set my homeing routines up and used some particle board and mdf I had laying around to put down a sacrafical table and did a couple of surfacing passes.
    One thing for sure a dust shoe needs to come quick. I'm trying to come up with something quick to get it on there. (What this really means is a reason to keep playing with the machine).
    So anyhow I've just been having a blast the last few days.
    I havent' installed any switches for the Z axis and am not sure when/if I will.
    I haven't got the router working though Mach yet, have been setting the speed via the knob.
    Thanks for looking.
    BobL.
    Attached Thumbnails Attached Thumbnails XYZ Gantry Build with Rotary Axis-100_0295sm.jpg   XYZ Gantry Build with Rotary Axis-100_0297sm.jpg   XYZ Gantry Build with Rotary Axis-100_0298sm.jpg   XYZ Gantry Build with Rotary Axis-100_0304sm.jpg
  • #127
    Apr 2011
    Good job Bob,
    Nothing better than starting to cut. Your machine looks great and your going to really like it. Keep working on a z limit switch, I would be lost without mine. Make's setup so much better. Keep us updated.
    Will
  • #128
    Jan 2007
    U.S.A.
    Z-Limits?
    Quote Originally Posted by WillsCNC View Post
    Good job Bob,
    Will
    I'm surprised you find your Z limits so valuable.
    I zero to the top of the workpiece and if you're going to plunge the bit into the work then a limit won't stop that.
    As far as the upper limit I figure a soft limit will work. Even driving the Z to the top just caused the motor to stall.
    Of course I don't tend to run the machine without keeping an eye on it in some fashion.
    But then I'm often wrong around this place so am eager to find out if I'm missing something and correct for it.
    Thanks,
    BobL.
  • #129
    Apr 2011
    Bob,
    Using the soft limits should work just fine. The z limit is just a stop for me. Your little baby is really looking good. Keep us updated.
    Will
  • #130
    Jan 2005
    Bob,
    Sounds like you are getting there. I will try to stay tuned better than I have been recently.
    Had a minor flood here so have been busy. With any luck I will have an office back in a few weeks.
    Its been a good thing.
    The rebuild to my CNC is on hold as it was in the middle of the action.
    My router was outside in my shop so other than boxed in with a few treasures its ready to run.
    I am looking forward to seeing more of the first steps and cuts.
    Dave
  • #131
    Jan 2007
    U.S.A.
    Sorry to hear that Dave, hope the flood didn't cause too much damange.
    On my end I am losing steps in the Z axis but I don't think it's mechanical.
    Haven't had any shop time this weekend so looking forward to going out and taking some readings.
    Good Luck,
    BobL.
  • #132
    Jan 2007
    U.S.A.
    Z axis losing steps solved !
    I had this annoying issue with my Z axis. After running a given job the Z would have missed steps. It was consistent across many runs. I was fairly confident it wasn't mechanical but it took me a while to find it. In the end it was a configuration setting. Had to be set by me but I'm going with an errant mouse click when setting things up.
    Here's my version of what was happening.
    On the Z axis pin settings on the computer I had the DIR pin to the motor set to trigger on the falling edge of the pulse and the STEP pin to the motor set to trigger on rising edge of the pulse. Don't ask me why it was set that way?
    The drive manual says the DIR input must be true 200 nanoseconds before and after the STEP pulse edge. Sounds like the pulse was able to meet this criteria until the timing caught up with it and a step pulse was missed. The software put out the pulse (so it counted it) but the pulse timing caused the drive not to fire. This added up and due to the cyclic nature of the timing it was off the same amount for a given size job. Makes sense now, but was a bear to find.
    This could have much, much worse. This is great !
    BobL.
  • Page 11 of 16 FirstFirst ... 891011121314 ... LastLast
    1. New 4x4 XYZ Gantry Build
      By WillsCNC in forum XYZ Gantry Routers
      Last Post: 11-07-2011, 07:58 PM
    2. Wanting to Build a 4th Axis / Rotary
      By CNC-Joe in forum Benchtop Machines
      Last Post: 05-25-2011, 05:27 AM
    3. Heavy large scale gantry mill/router/3d carving 5 axis build
      By Tristar500 in forum DIY CNC Router Table Machines
      Last Post: 03-18-2010, 07:07 AM
    4. New Machine Build- First build! 3-Axis Gantry-style CNC
      By TheBakachan in forum DIY CNC Router Table Machines
      Last Post: 04-17-2009, 09:10 PM
    5. Rotary 4th axis build componants & tech ?
      By Cruiser in forum General Metal Working Machines
      Last Post: 09-04-2007, 05:59 PM
