Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > X3/SX3/G0619/G0463
X3/SX3/G0619/G0463 Discuss X3/SX3/G0619/G0463 milling machines here!
Old 02-28-2007, 11:53 AM
BrendaEM is on a distinguished road
Sieg X3 Ways Large Enough?
The X3 is a large machine, but from the pictures I've seen, I have wondered if the ways are large and strong enough for the table.
Is there enough bearing surface there to hold accuracy for long-term repeated use?
Has anyone tested or needed to do any mods on the X3 ways?
(Thank You)
Old 02-28-2007, 10:52 PM
in2steam is on a distinguished road
Although the x3 is not exactly super high precise machine it seems well designed. If I am looking at the pictures correctly it has a little over 8" on the table for ways which is more then half of the table contacting at once. If you through up a 600 piece of iron on the table on a regular basis I think you may have issues. Its been my exeperice that over zealous operators over tighten the gibs and cause more damage then anything else. As was the case on a friend of mines atlas mill.
One of the beauties of iron is that you can scrap it back(or grind if desired) should it wear more then desired, you could I suppose use Moglice and build it back up should it hollow also. These machines have been around for awhile now and I am sure there is someone who has worn theirs out but I have not heard about it on any regular basis. Machines like this design were used for years on 3 shift operations before they needed to be scraped, granted that was US iron, and in alot cases alot bigger but the formula is still pretty much the same. If you keep it lubricated, level, and un abused it should more then likely out last you. I have not seen nor heard of the any mods to the table to increase rigidity or tolerance other then the typical cnc mods.
I would be more worried about the spindle or motor long before the bed. My thoughts at least, I am awaiting a break in the snow to get my x3 ordered so I can get it home. If I have to wait much longer I might as well order the Sx3.
chris
Old 03-01-2007, 10:43 AM
phantomcow2 is on a distinguished road
I am completely impressed by my X3. I was wondering about the ways too, judging from the pics. But I think pics distort them or something. I have zero chatter, and take deep cuts frequently. There is plenty of contact, and the ways are fairly wide.
Cheap sliding ways chuckknigh DIY-CNC Router Table Machines 6 02-04-2009 09:21 AM
Where to find ways? ZipSnipe General Metal Working Machines 6 03-26-2006 06:37 PM
Scraping ways will_eng General Metal Working Machines 4 08-22-2005 11:01 PM
box ways heilcnc General Metal Working Machines 0 03-02-2005 07:44 PM
Scraping in ways Rob D General Metalwork Discussion 12 09-22-2004 04:58 AM
