Get a clue and learn how to machine!
After building a bench and lifting the mill onto it, I got to
accuracy measurements today.
A) .0001 (tens) indicator, mag mounted to table, against exterior of spindle
NO READING. 0 . Yes, I quad-checked I had contact and no stuck
indicator
B) .0005 (5 tens) indicator, mounted in the spindle, lowered for the contact point to contact table. Eliminated cosine err as much as I could. Full motion in X.
indicator . Didn't do Y .
C) same, mounted in the spindle, ~6" sweep of the table. I could not lower
the indicator for the contact to touch the table, so I used 123 block on the
table ($5 variety). I got may be .0002 (2 tenths) needle motion, but I think it is the block .
Plowed through some 6061 with 3/4 4Fl EM, @ max rpm. It cuts to about .300
DOC, full width. The motor clearly loads up, but the mill is rock solid. I think
it can take 2HP (3Phase + VFD or straight DC, assuming you can find honestly-rated 2 HP DC motor for less than what I paid for the mill). I never hog metal like that anyway, but it is nice to test the limits.
I am in mill heaven ! Long live Harbor Freight and PROC.
Good for you rashid11. Hope it works out well for you. Sounds better than I would have thought.
RALLY Are you always so negative!
Now is that anyway to act!
Rashid, did you try that cut in low range? just curious if you'd be more productive. Also, a 2 flute and cutting oil would probably get better results.
rashid11, Sorry about that harch comment, but if you're really looking to check something use the machine for a few weeks then set up Indicators on both X and Y and see if the machine will repeat. If you know what that means!
Here is a note on the side, Steppers will loose steps if they are being pushed to hard so I would suggest you take it easy on the plunges and up your feeds.
PS: My Wife also thinks that I'm a smart Ass!
He said it "loads up" he never said it "boges", I think you were meaning Bogs. And I've never heard spindle bearings say anything? you need some sleep.
A 0.3 DOC in Aluminium with a 0.75" 4 Flute End Mill on a machine that is rated to take 1" end mills is not over doing anything. I calculated his cut to under 1hp or ~734Watts @ 0.002" per tooth/rpm, far from maxing the motor out, i'd do the same.
Ya what he said, go take a nap Rally![]()
I'm interested to know how much the final cost to you was over at harbor freight.
It seems Grizzly sells them for $1050 with shipping.
Did you use the harbor freight 20% off coupon? I am really in need of one, so If anybody has it and isn't going to use it, could you send me a PM please?
-Brandon
Those #'s are very consistent compared to what I found with my X3.
A .3" cut should be just fine. With 6 flute 1" rougher, I can take .25" off at a pass without bogging the motor down. No chatter either
