Results 1 to 4 of 4
Thread: fast spindle x4 for sx3
    ata
    ata is offline
    Registered ata's Avatar
    Jul 2006
    Indonesia
    Hallo.
    I have cnc syil sieg sx3 and i will change the spindle with the super spindle from syil x4. Is that possible? Thanks.
    Dec 2010
    no clue. but I am posting a video right now of my spindle speed increase
    Apr 2009
    Belgium
    I have a sx3 with R8 spindle and I want to update it with the SK/BT30 spindle from the X4...
    Have you an idea where I can found one?
    May 2007
    Factory SX3 and X3 spindle is 60mm for the spindle assembly. The X4 is 70mm so unless there is enough metal to bore out to 70mm then it is going to be tough. The castings apparently are very different based on the spindle drawings I have seen at Little machine shop.
    I don't have anyone around here that I can take it and bore it out for me that I would trust.
  1. How fast a spindle motor should I get?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 08-05-2010, 04:12 AM
  2. Need Help!- How fast a spindle speed can you really use?
    By leeputman in forum Metal Working Tooling
    Last Post: 03-03-2009, 04:25 PM
  3. are router spindle speeds too fast for flexidrives?
    By adamchapman in forum WoodWorking
    Last Post: 02-07-2009, 07:59 PM
  4. Spindle speed showing 2x to fast
    By fatal-exception in forum Mach Mill
    Last Post: 10-19-2007, 12:12 AM
  5. Spindle speeds - why so fast?
    By Cowbell in forum General Metalwork Discussion
    Last Post: 01-19-2006, 08:07 AM
