Results 1 to 1 of 1
Thread: X3 Mill Z-axis bearing block wear issues
    Oct 2011
    Folks,
    I noticed during my X3 CNC conversion that the bearing block (seat) at the bottom of the Z-axis screw only has thrust bearings and no radial bearings. This is part# 134 from the X3 parts list. Since my CNC fusion kit has a pulley attached near this point there will be side loads that could wear out the surface of the bearing block bore or ball screw shaft. What do you'll think about this issue? For now, I'll just pack it with a bunch of grease. Later, I was thinking of purchasing a spare bearing block from Grizzly and then milling out a small pocket within the block to house a radial type bearing like below:
    6801-2RS Bearing 12x21 Sealed 12x21x5 Ball Bearings
    Danh
    Attached Thumbnails Attached Thumbnails X3 Mill Z-axis bearing block wear issues-img_1678.jpg   X3 Mill Z-axis bearing block wear issues-img_1680.jpg   X3 Mill Z-axis bearing block wear issues-img_1672.jpg
  1. Question about part chatter and spindle bearing wear
    By MadMax in forum Daewoo/Doosan
    Last Post: 12-11-2010, 11:22 PM
  2. Problem- Z bearing block
    By In-Spec in forum Joes CNC Model 2006
    Last Post: 01-17-2010, 01:15 AM
  3. Bearing Block For Y axis
    By Mcyoda in forum Linear and Rotary Motion
    Last Post: 05-16-2009, 04:05 AM
  4. Thread Wear Issues
    By tanky321 in forum Linear and Rotary Motion
    Last Post: 03-03-2008, 09:42 AM
  5. Soft Wear Issues
    By bean7795 in forum General CAM Discussion
    Last Post: 04-15-2004, 11:09 PM
