I have a G0463 mill that I am installing a KBIC-125. Can I reuse the forward/reverse switch on the existing milling. My switch has 4 wires which include feedback connections (k0/K1). My question is do I need to install a different switch, using the existing switch and leave k0 & K1 unconnected or is there an option to install the K0 & K1 wires on the KBIC-125.
There are two methods used when reversing the KBIC-125, when you reverse the DC armature side, you must either disconnect the input power to allow a reset, OR simultaneously use the two disable pins I1 & I2.
See the note in the manual.
