Page 1 of 2 12 LastLast
Results 1 to 12 of 22
Thread: CNC Fusion Deluxe X3 Backlash
    Dec 2007
    Unhappy CNC Fusion Deluxe X3 Backlash
    Just completed my Grizzly "X3" conversion with cnc Fusion deluxe ball screws and the helical couplers he sells and I am getting .005" backlash in X and y. With the gibs completely loose I get .0015" back lash and with the gibs slightly tightens down I get .005. I checked everything and made sure all screws are tightened. It seems like the springiness of the couplers is causing the problem but I am really not sure.This is pretty disappointing to say the least. Any ideas?
    Feb 2010
    I'd say your assumption is correct. I'd replace them with the Oldham style couplers. My X2 conversion for CNC fusion used Lovejoy coupling with rubber spiders. I had around .005" backlash as well. Luckily Lovejoy has the .dxf files of their spiders online so I downloaded them and CNC'd out spiders made of an old cutting board. My backlash went down to .002".
    The Oldhams are easy to make. The insert is cheap enough it's probably not worth making that part however.
    Dec 2010
    I have identical results (well- .0043 on x and .0031 on Y)
    it was causing error on long runs when I had the backlash adjusted to the thou.... then I started auditing then by moving positive to zero, more positive part zero, make 15-20 moves then go back to zero. adjust accordingly.
    I can run a 90 minute program with 6 tool changes and zero back on my origin within a few tenths of zero.
    it really is frustrating that tightening the gibs INCREASES backlash. I've torn everything apart twice and can't get it any better, but it will have to do.
    not as annoying as the small head nod I get every z+ move. lovely little circles in an otherwise beautiful finish :-/
    Oct 2006
    I don't think the couplers are your problem. They should be on the opposite side of the bearing block, and the bearings preloaded before it. There shouldn't be any axial movement of the screw at the coupler.
    Naturally, the tighter the gibs are, the more backlash you will see if any of the sloppiness is hidden in bearings that seem tight and that sort of thing. When it can move freely, without resistance, the friction in the problem areas keep them from shifting, but when you tighten the gibs to the point of overcoming that friction, you will see the movement if it's there.
    That may or may not be your problem, but I would make sure all of the bearings have clean mating surfaces, etc. and increase the preload to see if that changes it at all.
    Dec 2010
    this is my first experience with ball screws and my knowledge is limited to what I learned from web research (which just isn't as good as hands on). I am not sure HOW to correctly increase the preload I think. I tried tightening the nut on the outside of the bearing on the X+ end but couldn't. even with the mortis holding it would just turn the screw.
    what's the"right" way? is it like adjusting the gibs "just by feel"? I think I would have to clamp the un threaded section with vice grip and shop rag to even move it.
    Nov 2009
    washington state usa
    Have you tried lapping the ways? It allowed me to run the gibs a little tighter, I did it after I machined the ways for oil passages, made a huge difference
    I have that same kit and I can only measure .001-.002 of BL on all axis
    Spend alot of time refitting the Z gib and your nod problems will be minimized drastically.
    JTCUSTOMS
    "It is only when they go wrong that machines remind you how powerful they are."
    Clive James
    Dec 2010
    I hand lapped and straightened the z but I an sure it would be best to start from scratch
    I also used the aluminum polish lapping method for HOURS just to get to 60% smooth. I'm sure it improved it from where it was. I'm thinking back and don't remember breaking the ball nut loose when I took everything back apart last time. maybe loosening and tightening it with the screw re adjusted will help ::shrugs::
    Feb 2010
    Quote Originally Posted by Winnfield View Post
    The problem with the Lovejoy couplers is that they allow the stepper to rotate, compressing the spider, but the screw isn't rotating yet. So I guess it's not backlash in the traditional sense, but more like virtual backlash...
    Oct 2006
    In the original post, he said he is using helical couplers, so I think he can probably rule out that as an issue.
    May 2010
    The helical couplers that I originally used on my router were complete junk. You could see them winding and unwinding slightly with every reverse of the axis'. I replaced them with an oldham style coupler and was very happy with the results.
    I suppose there are good and bad helical couplers......just like anything. Mine were turds........well, they could have been turds if they were a little better.
    Feb 2010
    Helicals may actually be worse. If you think about it, they are nothing more than a spring. If you have large steel helicals, it may not be an issue, but a 1" aluminum one would be springy.
    Oct 2006
    I see what you mean - virtual backlash sort of thing. That makes sense. I guess I have never seen any that do that, but can certainly see where it might be an issue if they aren't robust enough.
  • Page 1 of 2 12 LastLast
    1. Need Help!- CNC Fusion X3 Deluxe Kit Ball Nuts
      By ltlbull in forum Benchtop Machines
      Last Post: 03-01-2011, 11:01 AM
    2. Q on CNC Fusion Deluxe Y ballscrew for X3
      By rezcar in forum Benchtop Machines
      Last Post: 12-19-2009, 07:36 PM
    3. SNEAK PEAK: CNC Fusion X3 Deluxe kit
      By wisp in forum Product and Manufacturer Announcements
      Last Post: 03-10-2009, 12:01 AM
    4. CNC Fusion Deluxe X3 Ball Nut Issue
      By dneisler in forum Linear and Rotary Motion
      Last Post: 04-15-2008, 11:01 PM
    5. CNC Fusion X3 Deluxe Kit Backlash Issues
      By dneisler in forum Benchtop Machines
      Last Post: 09-25-2007, 05:39 PM
