Results 1 to 5 of 5
Thread: Tormach tooling SX3/MT3
    Jul 2006
    Norway
    I just received some Tormach tooling today from LMS. I decided up on TTS for my mill after a lot of good feedback around here and a few other forums. But there seems to be some issues with the 3mt collett. After what i believed it was supposed to drop easily with just a few rotations on the drawbar. Mine is as stuck as other 3mt tooling. I have to whack it out with a rubber hammer to release it. That is bad news for ATC and easy tool changes.
    Is there anyone else that have had similar issues? How does your TTS tooling behaves?
    Cheers
    Jan Rune
    Registered eartaker's Avatar
    Jul 2009
    USA, Tacoma, WA
    Pick up a tube of anti-seize from the hardware store and it will help keep the collet from sticking. The ATC's and power drwawbars don't have any issue with this since they use spring washers and push down on the drawbar to release the collet like you are doing with your hammer. You could just smack it with your wrench and it would be enough to release it but you should also use some anti-seize.
    Jermie
    http://www.eartaker.net http://thehorticulture.net
    Tinkerer
    Nov 2009
    Arent the TTS collets for R8? I didnt know they had both.
    Jul 2007
    Yep,
    Tormach Tooling System - Miscellaneous Tools | Tormach | We provide personal small CNC machines, CNC tooling, and many more CNC items
    Their 8" rotary table has an MT3 taper allowing you to use TTS for work holding.
    bob
    Dec 2012
    Belgium
    i just bought the HBM x 2 dc mini mill.
    but am realy confused wich tts is for the x 2
    on one spot they say its mk3 on a other its b16 then its mt3
    going nuts ...
    also i work with metric sizes.
    so any info would be great.
    ( just starting out.)
    1. anyone have too much tormach tooling?
      By Teyber12 in forum Tormach Personal CNC Mill
      Last Post: 02-21-2010, 08:15 PM
    2. New Modular Tooling from Tormach
      By ag53711 in forum Tormach Personal CNC Mill
      Last Post: 07-22-2009, 09:27 AM
    3. Tooling for tormach
      By RP Designs in forum Tormach Personal CNC Mill
      Last Post: 12-13-2008, 04:27 PM
    4. Tormach tooling in an X3?
      By JFettig in forum Benchtop Machines
      Last Post: 03-11-2007, 02:27 PM
    5. The Tormach Tooling?
      By Willyb in forum Tormach Personal CNC Mill
      Last Post: 01-11-2007, 08:47 PM
