I'll be using the CNC Fusion Deluxe kit for the mechanics.
I contacted Keling for recommendations for an X3 CNC conversion-parts recommendations. The parts he suggested are below. I was a little surprised no Gecko drivers were recommended. I'd appreciate any feedback from the forum before committing to this purchase.
I will be using flood-coolant and hope to do a belt drive conversion for higher spindle speeds. I'm mainly cutting .090" 6061 aluminum sheet and engraving acrylic plastics with a .020 end mill. I will also be using the MPG2 pendant.
I thought the G540 would handle both the coolant pump signal as well as the spindle control, along with it's fantastic reputation. I trust Keling since many folks here use them, but I thought I'd check here for any additional input.
Thanks for your feedback.
3 -- KL-5056 Stepper Motor Bipolar driver with heat sink
1 -- NEMA34 KL34H295-43-8A(B) ( HIGH TORQUE STEPPER
MOTOR 906 oz-in for Z axis
2 -- NEMA23 KL23H86-20-8B Dual Shaft Motor 425 oz-in,
1 -- 48V/12.5A Power Supply: Input 115V/230V
1 -- C11G, 6 axis Breakout Board with relay and spindle control
1 -- 5V power supply
LinkBack URL
About LinkBacks
