Page 4 of 4 FirstFirst 1234
Results 37 to 44 of 44
Thread: Digging the X3 out of Storage.
  1. #37
    Apr 2003
    Paris, Texas
    What you are seeing in the pic is the actually pulley on the shaft, there is not threads exposed. The weight and pulley are one chunk of metal.
    Donald
  2. #38
    Gold Member hoss2006's Avatar
    Apr 2006
    If it's tight, take a c-clamp and tighten it on the flywheel.
    Then it usually only takes a good whap on the clamp while holding the motor
    in your lap or on a table to pop it loose.
    Momentum is usually enough so you don't need to hold the shaft in anyway.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  3. #39
    Apr 2003
    Paris, Texas
    I will give that a try tonight, so far I have not got it to budge.
    Donald
  4. #40
    Apr 2003
    Paris, Texas
    Well so far C clamp and hammer is a no go....next suggestion?
    Donald
  • #41
    Apr 2003
    Paris, Texas
    Finally after allot of persuasion it came off.
    Now I have to figure out how to mount a pulley on this none keyed shaft.
    Donald
  • #42
    Apr 2003
    Paris, Texas
    I got a little time in the shop today, not much. Hard to get much time when you work a fulltime job, and run a home business as well.
    Here are couple pictures of my "Simple Tram" as i have been calling it. I just need to figure out what size shaft to put in it and it will be done.
    Attached Thumbnails Attached Thumbnails Digging the X3 out of Storage.-simpletramfront.jpg   Digging the X3 out of Storage.-simpletramback.jpg
    Donald
  • #43
    Dec 2010
    very nice looking! I would go 3/4" so it will fit with TTS collet.
  • #44
    Apr 2003
    Paris, Texas
    Thats what I was thinking, but I used material I had already, so it is only .70" wide. I use a ton of 3/8" stuff and I have not TTS right now, so I am leaning towards 3/8".
    Donald
  • Page 4 of 4 FirstFirst 1234
    1. Drill bit storage...
      By Spinnetti in forum General Metalwork Discussion
      Last Post: 02-20-2011, 02:00 PM
    2. Program storage BB0:
      By Voss_Machine in forum Okuma
      Last Post: 10-15-2010, 11:02 AM
    3. Storage of end mills
      By eaglezsoar in forum Metal Working Tooling
      Last Post: 05-27-2010, 01:47 PM
    4. 4th Axis storage
      By R.DesJardin in forum Tormach Personal CNC Mill
      Last Post: 03-19-2010, 10:55 AM
    5. Storage
      By seb fontan in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 01-16-2005, 01:05 AM
