Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 28
Thread: ramkitty x3 conversion
  1. #13
    Mar 2011
    I am glad to have found this tread. I am planning on doing almost the same conversion on my 463 but was planning on a gecko 540 for a controller at 48v. Is there a real big advantage in the deluxe kit over the standard kit?
  2. #14
    Oct 2010
    Red face
    The backlash is greatly reduced in the deluxe kit as well as it having ground screws which are more accurate over length. If you are thinking about doing any of the upgrades to the basic kit might as well save for the deluxe kit. I still think I will be fine with what I have just running at slower rates, especially the z. The gas strut made a huge difference I am able to raise and lower the head using my fingers on the z axis ballscrew gear.
    As an update I have all the wires cut and am starting to assemble them. I plan on running all the cables from the tables to the electrics box in the back then using amphenol mil connectored cables to an external box housing the cnc electrics. I tested the TB6560 3 axis motor controller for the limit switches and the and estop I determined that the board has internal pullup resistors which will make the wiring a little easier to deal with. I also did something a little unusual in wiring the stepper motors. I cut the external wires short and using plastic braided wrap over the 2 pair shielded cable I connected the stepper for bipolar parallel operation. I used dual wall heat shrink (has hot glue inside) and shrank the braid to the cable covering up the connections (pictures to come). Since I am connecting bipolar series for the time being I removed the end cap from the stepper and rewired it to run in series. I did this so I can have the cable sealed from day one. To switch to parallel I will have to quickly remove the internal jumpers and reconnect to the 8 external wires. The z axis motor will be untouched as it is internal to the electrics box and I will just change the wiring on the connector to the cnc box.
  3. #15
    Mar 2011
    have we determined what oz of stepper motors we really NEED with this conversion? The gecko 540 is not really recomended for use with the 1203m oz stepper or any nema 34 stepper. Have not ordeded them yet since they will be in probably before the conversion kit.
  4. #16
    Feb 2006
    Quote Originally Posted by ramkitty View Post
    ...the deluxe kit as well as it having ground screws which are more accurate over length....
    I SERIOUSLY doubt the deluxe kit has ground ballscrews....
    Regards,
    Ray L.
  • #17
    Nov 2009
    washington state usa
    They are NOT ground ballscrews with the deluxe kit
    Good luck getting 1 ground ballscrew for the price of the deluxe kit
    JTCUSTOMS
  • #18
    Oct 2010
    I am quite wrong, digging in the forums i found that "the deluxe screws are rolled to a higher precision"
  • #19
    Dec 2010
    Quote Originally Posted by sonic1954 View Post
    ...The gecko 540 is not really recomended for use with the 1203m oz stepper or any nema 34 stepper...
    I'm more of a mechanic than a machinest and what little I know is from reading this forum preparing to convert my x3... but you statement scares me.
    is this correct? is the G540 not recommended for nema 34? I an planning on buying the kit from keling which includes a G540 and nema 34. is this bad???
  • #20
    Mar 2011
    Scared me too! From my further reading, it should say it should not be used with any stepper requiring more than 3.5 amps. A lot of the Nema 34 motors exceed that but there are some that do not. I am just reading that from the gecko spec sheet. That is what it states. 0 to 3.5A rated phase current.
    Be sure your power supply is adequate amp output to handle all your motors!
  • #21
    Nov 2009
    You can use nema 34's you are just limited to 3.5 amps output on the G540,
    The 906oz nema 34 that I have on my SX3 works great it is just de- rated, because of the 3.5 amp limit.
    JTCUSTOMS
    "It is only when they go wrong that machines remind you how powerful they are."
    Clive James
  • #22
    Oct 2010
    finished the mill conversion I have yet to make the electrics box and hook the computer up to the machine but that will have to wait as I leave first thing in the morning for 2.5 months of military training
  • #23
    Dec 2010
    rats! I have been patiently awaiting the conclusion of your build
    good luck with your training and keep us posted when u get back.
    by then I should have started building my shiddySX3CNC
  • #24
    Oct 2010
    thanks I will be posting some pictures when i get to ontario but you can blame it not being finished on the electronics supplier I got the connectors from, they misordered the parts i wanted
  • Page 2 of 3 FirstFirst 123 LastLast
    1. New Machine Build- Jet another X2 conversion
      By ellik in forum Benchtop Machines
      Last Post: 12-20-2009, 05:43 PM
    2. servo conversion vs stepper conversion
      By contractdesign in forum Bridgeport and Hardinge Mills
      Last Post: 07-26-2008, 03:54 PM
    3. My X1 CNC Conversion
      By zwdeal in forum Benchtop Machines
      Last Post: 05-21-2007, 10:05 AM
    4. a conversion Kit for CNC
      By US-GUN'S in forum Benchtop Machines
      Last Post: 08-10-2006, 11:23 AM
    5. DC to Ac conversion
      By DragnsBane in forum General Electronics Discussion
      Last Post: 03-07-2005, 09:38 AM
