Results 1 to 4 of 4
Thread: Sieg KX3 Spindle Gear
    Mar 2011
    Does anyone know how to remove this gear from the KX3? Is it pressed on? Threaded on?
    Oct 2008
    Does it sit on top of a retainer/bearing plate with 4 screws? If so, then it's like the SX3 and you remove those 4 screws, and the entire pulley and bearing plate slides off by hand. Then there are 2 snap rings you remove to press the pulley/hub out of the bearings.
    I'm using KX3 parts on my SX3 for higher speeds and so far everything has been bolt on.
    Richard
    Rev
    SX-3 Mill, 10x22 Lathe, RF-45 Mill, GH-1340 Enco Lathe
    Mar 2011
    Yes, it does. I unbolted the mounting plate, and although I can turn the mounting plate, the assembly doesn't want to lift out. Any ideas?
    Attached Thumbnails Attached Thumbnails Sieg KX3 Spindle Gear-img_20110315_185914.jpg
    Nov 2009
    washington state usa
    Give it a couple of light taps with a hammer (not on the pulley) and it should work itself loose, there are 2 snap rings on the bottom, one holds the pulley in place while the other retains the bearing, on mine the pulley was a pretty tight fit in the bearing though
    JTCUSTOMS
  1. Sieg X3 Spindle motor
    By rcotteleer in forum Benchtop Machines
    Last Post: 09-29-2010, 04:25 PM
  2. Sieg X1 brushless RC spindle motor
    By mbasecnc in forum Benchtop Machines
    Last Post: 09-04-2010, 06:16 AM
  3. Sieg X3 Spindle / Motor Problem
    By Trey54 in forum Benchtop Machines
    Last Post: 03-07-2010, 09:41 PM
  4. Sieg X3 spindle problem (?)
    By kevin.doherty in forum Benchtop Machines
    Last Post: 05-18-2007, 10:09 PM
  5. Sieg X1 Spindle
    By itsme in forum Benchtop Machines
    Last Post: 01-23-2007, 07:05 PM
