Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 34
Thread: Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2
  1. #13
    Registered Prefect's Avatar
    May 2009
    Unfortunately my server is seriously lacking in bandwidth... I'll see about posting here as well.
    I got my engraving bits from an ebay vendor. There are several vendors selling them, but here's the one I used: http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
    Quote Originally Posted by Teyber12 View Post
    i have spent the last 10 minutes trying to get the pictures to load. it looks like top quality but man i sure wish i didn't have to spend all morning try to see it. I think you should post all your pics and write up here as well. even if you just copy and paste it and throw img tags on the pictures.
    i need engraving bits. What did you use for the engraving?
    cheers
  2. #14
    May 2009
    Writeup from my blog post...
    My friend Dan built the electronics for a temperature controller for his electric smoker. I figured since I have the CNC mill, it was a moral imperative for me to do some nice enclosure work for him to make the project look slick. Dan admitted his initial attempts at the case work with a Dremel tool were lacking somewhat, so about a month back he passed the guts over to me so I could have a go at it. It took a few attempts to come up with a design I was satisfied with and execute it well enough to consider it done, but I chalk all of that up to gaining experience on the machine. I was pleased to finally be able to present the finished product to him last night!
    The electronics originally fit into a waterproof PVC Carlon box. The lid had been previously attacked with a Dremel, but I figured if I cut out a large window and made an insert for it, we could salvage it as well as end up with a nifty look. So, I started out by CNC milling out a roughly 4.7″ square from the lid. I then made a clear polycarbonate insert, just slightly smaller by about 0.010″, so it would slip fit inside and stay in place with a flange. The polycarbonate insert received some decorative milling on the front panel, and some functional drilling on the rear panel to provide mounting and a place for the knob to pass through. The insert also got an engraving treatment with some text using the new high speed spindle mount that I built last week. Since getting engraving working well, I had tried a few experiments of back painting engraved text. I did the same for the Smoke-O-Tron, using some water-based Rust-Oleum hobby paint. I made sure the see-through LCD window was well masked off with the original paper that came with the polycarbonate as well as some supplemental electrical tape. I sanded the back of the insert, avoiding the LCD window, with 220 grit in my random orbit sander, and applied a couple of coats of black spray paint.
    The main electronics consists of the main PCB and a small character LCD. After one misguided attempt of doing blind tapped holes in the clear insert (ugly and visible), I came up with the much cleaner “mezzanine” approach. This is often done in front panel work in devices, especially when varying heights have to be accounted for. The particular scheme I chose allowed a completely clean front panel look with no visible screws. The electronics mount to both sides of a small polycarbonate plate, and the plate itself is mounted to the PVC enclosure by way of some custom-length standoffs. The standoffs also serve to sandwich the front panel PVC insert in place.
    I also made a quick shaft adapter/extender for the encoder wheel, which adapts from 6mm to .250″ and provides a long enough shaft extension that passes through the mezzanine, front panel insert, and into the knob.
    All in all, I’m fairly pleased with the end product. It looks slick, and I have learned a few new techniques for future projects. As usual, here is a video which details the making of the enclosure, and a bunch of pictures as well (sorry, the pictures are out of order versus my blog post).
    [nomedia="http://www.youtube.com/watch?v=GFyCAy-ocFA"]YouTube- Fabricating the "Smoke-O-Tron" Enclosure[/nomedia]
    Attached Thumbnails Attached Thumbnails Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2-smoke-o-tron-.jpg   Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2-img_0651.jpg   Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2-img_0654.jpg   Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2-dsc_4890.jpg
    Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2-img_0625.jpg   Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2-img_0637.jpg   Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2-img_0646.jpg   Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2-img_0650.jpg
    Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2-img_0616.jpg   Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2-img_0633.jpg   Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2-img_0634.jpg
  3. #15
    May 2009
    cheers
    For what it's worth I've made some bandwidth improvements on my blog site - it should be much speedier now.
    http://www.tangentaudio.com/
  4. #16
    May 2009
    Well, I pulled the trigger today and ordered the full Tormach CNC operator's quickchange tool set, plus the holder for a dial indicator, as well as one of the slip-fit rings to convert the holders to ATC, in case I ever go down that path...
    I decided that my reward for exchanging a 65 pound bag of metal (spare change) that I've been collecting for about 10 years would be a 32 pound box of different metal and granite from Tormach.
    Let me tell you, sorting and rolling that much change wasn't the best time I've ever had, but it should be pretty rewarding to have the Tormach stuff when it arrives. And it did beat paying Coinstar the 8.9% fee for sorting.
    One bummer is that they're back-ordered on the full kit until April 26th at least, so I've got a bit of a wait ahead...
    Another bummer is that it looks like the 5/8" tooling I acquired in my bulk ebay purchases won't be usable with TTS. I noticed Smithy sells a 3/4" tool holder, but I didn't see anyone selling a 5/8". Anyone need some 5/8 USA-made carbide endmills? Roughers, ball-end, and flat I believe.
  • #17
    Feb 2009
    Great job on the enclosure for the smoker. The vid was good also.
    I dont have any but have been looking at the Maritool stuff. You could have 12 ER25 tool holders and an array of 12 different ER25 collets for the price of the Tormach stuff, otherwise just a couple of ER25 holders and collets in 5/8 will be a nice adder to the TTS.
  • #18
    May 2009
    Those Maritool holders do look nice. If I'm not mistaken, you'd still have to epoxy on the metal ring that Tormach sells to give it a ground indexable surface for repeatable heights, right?
  • #19
    Registered Crevice Reamer's Avatar
    Mar 2008
    Quote Originally Posted by Prefect View Post
    Is TORMACH back ordered?
    http://www.tormach.com/Product_TTS_sets.html
    You can either make your own holders or use the machinable blank option:
    http://www.tormach.com/Product_TTS_misc.html
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
  • #20
    May 2009
    Quote Originally Posted by Crevice Reamer View Post
    CR.
    Yes, Tormach is back ordered on the TTS set. They said they expect a shipment of them by April 26 and should have the backorders fulfilled by the end of that week.
    I was wondering if the machinable blank would be practical for holding a 5/8 tool. I don't have a lathe yet, but I have been eying the Grizzly 10x22 and may get one this summer.
  • #21
    Nov 2005
    Why not just pick up an ER25 holder from Maritool? ER25 goes up to 5/8"
    FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
  • #22
    May 2009
    Quote Originally Posted by Enraged View Post
    That was mentioned last night; they do look like a good option and I'll probably get at least one holder and a 5/8" collet. They don't look like they have a precision surface to mate against the spindle face like the TTS tools do, but I could add the collar that Tormach sells (30675 on http://www.tormach.com/Product_TTS_misc.html).
  • #23
    Nov 2005
    thats what I was planning on doing. if you need collets, glacern has them at a good price.
  • #24
    May 2009
    Well, my Tormach set has arrived! I'm looking forward to getting my tooling mounted up and running my first job with the pre-measured tools and a fully loaded tool table.
    Attached Thumbnails Attached Thumbnails Grizzly X3 / ProMiCA "hardware only" CNC kit / Gecko 203V / EMC2-tormach.jpg
  • Page 2 of 3 FirstFirst 123 LastLast
    1. Grizzly G0602 10" x 22" Lathe Conversion
      By derekbackus in forum Vertical Mill, Lathe Project Log
      Last Post: 02-22-2013, 12:48 AM
    2. "Hardware" GCode interpreter
      By DukerX in forum Group Projects
      Last Post: 06-03-2011, 07:15 PM
    3. Newbie- First Machine HELP...24"x36"x4" or Larger Setup w/ Gecko for under $3000
      By buschhoff in forum Want To Buy...Need help!
      Last Post: 03-20-2010, 07:37 PM
    4. Replies: 1
      Last Post: 05-12-2009, 12:27 PM
    5. Calculating "steps per" in Mach3 with Gecko 203V
      By millman52 in forum Machines running Mach Software
      Last Post: 11-28-2007, 04:04 PM
