X3 X axis lead screw nut dimensions.
Results 1 to 2 of 2
Thread: X3 X axis lead screw nut dimensions.
    Jul 2006
    Default X3 X axis lead screw nut dimensions.
    Does anyone have or know where I can find the dimensions of the X axis lead screw nut block?
    I am doing a DIY CNC conversion on mine and I forgot to cad the original block before screwing it up
    I would love to find cad files for the mill. I did find a fusion 360 model of the mill, but it was only the big parts with none of the smaller parts IE lead screw supports lead screw nuts .
    Thanks.
    Nov 2005
    Default Re: X3 X axis lead screw nut dimensions.
    I just happened to measure that last night. 25mm x 60mm x 34.97mm in X, Y, & Z directions.
