| Work Fixtures and Hold-Down Solutions Discussion Modular workholding, Hogout workholding, Automation workholding. Hydraulic workholding, Jigs and Assembly workholding here. |
| Hello: I am having a problem with my Chick vises. I am using 4 dual Chick vises, MLQ 1040. It seems that when I go to clamp my parts, one side of each station pushes up my part by .015", and so I get a screwed up part, that is not parallel. I called Chick and they that either my D-holes in the slide assembly are worn lose or my pins are worn down. So I am in the process of taking my Chick vises apart and cleaning everything. My question is, is there a way to add a shim in the D-hole to take up any slack ? Or is there another way to solve this problem ? Any help or tips would greatly appreciated. Thanks Sam |
Example: http://www.jjjtrain.com/vms/mill_squ...uaring_06.html
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
| That is an interesting idea. My parts are small and thin. In my Chick vises I have milled a 0.1" pocket, so there is not much room to stick a rod in there. I did follow Chick's advise, and that was to clean everything. Well in the process on doing that I discovered what my problem was. It was mainly with my stationary jaw. It seems that the 2 metal inserts in the vise had bonded into a some trash. So I cleaned some of that out and very slightly pushed those inserts down. Now, everything is leval as it should be. So I just saved myself over 1000 dollars from having to buy new slide assemblies. Sam |
#10
I have had the opposite problem of the pins being too tight (We make our own jaw blanks). When cleaning everything doesn't work I ream out the hole in the soft jaw. You might try milling a bit off the bottom of the jaws, that will bring the pin hole down and tighten up the D hole. |
| Chick System 5 vise 1040 | walter_58 | Work Fixtures and Hold-Down Solutions | 4 | 04-25-2009 12:02 AM |
| Machine Vises | stedgar | General Metal Working Machines | 0 | 06-08-2008 11:15 AM |
| Help for a beginner...end mills...vises | 725franky | General Metalwork Discussion | 23 | 07-23-2007 08:01 AM |
| programming multiple double vises | bink | G-Code Programing | 12 | 10-26-2006 10:07 PM |
| Are Parlec vises any good? | gearsoup | Work Fixtures and Hold-Down Solutions | 4 | 10-09-2006 07:11 AM |
