Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Work Fixtures and Hold-Down Solutions
Work Fixtures and Hold-Down Solutions Discussion Modular workholding, Hogout workholding, Automation workholding. Hydraulic workholding, Jigs and Assembly workholding here.
Old 03-28-2008, 10:03 PM
svatchi is on a distinguished road
Working with stock thickness material.
Good Day. Has anyone run into this? Working on a project that uses stock thickness plastic material that has blind features dimensioned from the top surface of the part as it lays on the table. The materials carries tolerance of +/-.020 while the part requires +/-.010. In order to hold required tolerance, I need to fixture the top surface of the part at a plane parrallel to the table(Z=Zero). I also would need to cut radii on the outer edges of the parts. with material having varying thicknesses, the radii are not consistent. Any ideas? All are appreciated!
Svatchi
Old 03-29-2008, 09:36 AM
Juka is on a distinguished road
Svatchi
Maybe vacuum table is a right thing for you...
http://cgi.ebay.de/Vacuum-table-2818...QQcmdZViewItem
Jussi
Milling parts to stock and thickness ?s. Stampede BobCad-Cam 3 11-15-2007 03:42 AM
What is the greatest thickness mbkowns Vacuum forming, Thermoforming Etc 6 10-30-2006 10:33 AM
Mirror thickness CNCadmin Laser Engraving & Cutting Machines 8 08-04-2005 03:32 PM
head stock and tail stock chucks mocnc DIY-CNC Router Table Machines 3 10-19-2004 10:16 PM
