Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Work Fixtures and Hold-Down Solutions
Work Fixtures and Hold-Down Solutions Discussion Modular workholding, Hogout workholding, Automation workholding. Hydraulic workholding, Jigs and Assembly workholding here.
Old 02-15-2008, 10:49 PM
DSL PWR is on a distinguished road
5 minute venturi 5 dollar
Well I need to mill out some profiles in acrylic. I tried 3 types of double tape, and 2 types of hot glue to fixture the plastic down. After some limited success, and several exploding pieces of acrylic (think mythbusters exploding cds) I got some pieces made. After fighting with such a simple job I decided I should probably make a vaccum table. I will probably convert a cheap hotdog air compressor once I get going, but I figured I'd play around with a venturi first. So I scanned some of the venturi threads here and got to thinkin how could I do a "quikie".
I started to go thru some of my stuff and realized a mig tip is .25". Hmm too easy I say. I cut up some 3/8 plastic tubing (about .25" id) and stuck the .035 mig tip in there, and clamped it. Then I dug up a .25" pushlock tee, and stuck the mig tip in and hit it with some air. I felt a little pull on the branch, and I got excited (yeh, I need some better interests...). I pulled out my calibration gear (I'm a Jman at instrumentation) and checked the vaccum. I was pulling about 2.5 psi, but I could feel the air from the mig tip was "rough". Then I stuck in a piece of 1/4" tubing and it started pulling over 4 psi, so I say to my self "self, this is pretty cool". I started cutting off the 1/4" tubing untill it seemed to top out at over 5 psi vaccum. Judging from the air compressor run time I guestimate it uses about 3cfm of air at line pressure (95-120psi).
Not bad for 5 minutes, and 5 bucks.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 02-16-2008, 01:27 AM
DougO is on a distinguished road
That looks neat. thanks
Old 04-26-2008, 08:41 PM
tranbell is on a distinguished road
You need to use Permacell double tape for arcylic. It works very good
http://www.permacel.com/pdfs/i02.pdf
Made my own Venturi... Zippi Work Fixtures and Hold-Down Solutions 22 08-28-2011 05:36 PM
X3 6000 rpm for about 1 Dollar pzzamakr1980 Benchtop Machines 8 05-08-2008 12:19 AM
venturi suction system rajanish General Metal Working Machines 12 10-05-2007 06:58 AM
The 'Million Dollar' Me2 Open Source CNC Machine Designs 2 07-19-2006 03:53 PM
Venturi Vacuum Systems Moondog DIY-CNC Router Table Machines 6 09-24-2004 09:17 AM
