Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Work Fixtures and Hold-Down Solutions
Work Fixtures and Hold-Down Solutions Discussion Modular workholding, Hogout workholding, Automation workholding. Hydraulic workholding, Jigs and Assembly workholding here.
Old 11-25-2007, 06:40 AM
ISHY is on a distinguished road
Vacmagic
Does anyone have any experiance with a Vacmagic vacuum table? I have just bought one and the work slipped off on the first cut, I'm sure it must be me but the seal is as it should be and I have the correct air supply etc. Any input would be welcome.
Thanks,
Ishy.
Old 12-04-2007, 02:37 AM
Vac-Clamp is on a distinguished road
Hi ISHY,
From what I can see the Vacmagic table has a round rubber cord as the seal material. It may be more reliable to cut the cord to size and have the ends meeting one another. If that does not work see if you can glue the ends of the cord to improve reliability.
You may also need to give your work piece a bit of a push onto the face to make the seal work.
I assume that the vacuum pump/ generator is functioning well, and that all plumbing has no leaks
Errol at Vac-Clamp
