| Work Fixtures and Hold-Down Solutions Discussion Modular workholding, Hogout workholding, Automation workholding. Hydraulic workholding, Jigs and Assembly workholding here. |
I am looking for a vise or hold down solution for holding a peice of 31/32 round plastic peice vertically. But it cant be tall. Id like it to be under 1.5" max height. a vise with thick alum jaws would work. I would machine them to fit around the plastic. Any suggestions please let me know. |
| This is a pretty standard procedure called vice soft jaws. Take the standard jaws out of your mill vice and replace them with AL or soft steel jaws. You can just make your own. Tighten the vice up with a couple thickness of paper between the jaws. Bore your 31/32 hole right in the soft jaws. Remove paper and clamp in your part. Karl Karl |
Fasten a block of 1-1/2" aluminum to the table. Bore a hole for the size of the plastic. Cut a slit into the hole. Drill and tap for a bolt to close the slit and then you have a split clamp that will hold your part vertically.
A minute after posting I thought about doing it with two pieces. Makes it easier to separate the halves of the clamping hole.
| Locating Fixture | 123sxu | Work Fixtures and Hold-Down Solutions | 10 | 06-04-2009 11:18 AM |
| RFQ- small little round part needed | fastolds | Employment Opportunity | 2 | 12-07-2005 08:04 AM |
| Machining strategy - how would you fixture and machine this part? | SRT Mike | General Metalwork Discussion | 12 | 11-28-2005 02:36 AM |
| Self centering fixture | Hack | Mechanical Calculations/Engineering Design | 18 | 07-13-2005 12:09 AM |
| material for fixture | MBG | General Metalwork Discussion | 9 | 03-12-2005 02:37 PM |
