| Work Fixtures and Hold-Down Solutions Discussion Modular workholding, Hogout workholding, Automation workholding. Hydraulic workholding, Jigs and Assembly workholding here. |
Making Limit and Homing Switch actuator cams. Have the limit and homing switches mounted, now to make the cam actuators, They would be small pieces of angle aluminum and would have to cut them down even smaller of the cam side. I have not cut the ramps yet will do that later. When cutting small aluminum parts especially with wood working tools extreme caution should always be exercised. I came up with this method and it seemed to work safely, if you do not feel secure in doing it this way then don’t., always be careful and think about what you are about to do. Accidents happen so quickly. How I ripped one side of the aluminum angle narrower to turn it into a can actuator. Set the saw blade just high enough to cut through the aluminum. Set the rip fence to the desired width and secure it. Place angle against the rip fence. Slide a piece of would behind it to act as a pusher. Take a second piece and lay on top of the angle. Turn saw on. Hold down on the second piece of wood and push the assembly slowly onto and past the blade. Turn saw off. IMPORTANT: Let saw blade cone to a complete stop before removing the pieces of wood. Had the angle been narrower and there would have been a risk in the piece dropping into the gap beside the blade, I would have lowered the blade below the table surface, and clamped a piece of thin plywood to the table top and raised the blade making a zero clearance condition then cut the pieces. |
| Hager |
| Triple chip blades have a chamfer on the sides of the teeth. They're usually used on hard materials, like Corian, laminates, and non ferrous metals. http://www.freudtools.com/woodworker...24_LU90M_D.gif
Will have to check them out at HD. Hager |
One tooth is square cornered, the next has chamfered corners and the next square all the way around. In a good machine on aluminum they can produce a very nice finish. |
Is it called "triple chip blade" on the package. If not do I have to examine the blades to insure I get the right one. Hager |
| nice thing about using a simple carbide tipped wood blade is they are so cheap , i use my old blades for cutting aluminum , a couple weeks ago i was cutting steel tubing with one , to my surprise it works well and fast , though i strongly suggest eye protection if anything short of a face sheild ,and its a lil hard on the blade |
#10
Hager |
#11
| dertsap; if you are cutting a lot of steel tube get a friction blade and a chop saw with the fastest rpm possible. Dewalt has one that does 5400 rpm and also makes the blade; Home Depot has both. Cut almost anything in steel; mild, stainless, alloy, high speed steel and even carbide. We have a blade that has done around 25,000 cuts in 7/8"-16gauge stainless and it is still going strong. Carbide tends to kill them but it is possible to go through a 1/2" diameter in a few minutes. Sorry for the diversion Mr. Chips...back to aluminum cutting; which is not possible with a friction blade. |
#12
Have an old lab coat, put it on backwards, turn the collar up over your chin and wear a face shield that comes below the collar. This way you do not get the hot chips sneaking in between your collar and neck. |
| small cnc plasma table | morpheus | CNC Plasma and Waterjet Machines | 3 | 02-18-2009 09:58 AM |
| Best inexpensive servo setup for small 2x3 table | Ed Williams | Servo Motors and Drives | 6 | 08-28-2006 08:03 AM |
| Cutting long pieces | randyf1965 | DIY-CNC Router Table Machines | 4 | 04-26-2006 11:02 PM |
| Small Vacuum Table | CLaNZeR | Work Fixtures and Hold-Down Solutions | 7 | 04-16-2006 05:23 AM |
| CNC Lathe Cutting Small Threads | jbhill | Machine Problems, Solutions , Wireless DNC, serial port | 5 | 02-19-2005 09:53 AM |
