Results 1 to 3 of 3
Thread: Sliding (Spring Loaded Fixture)
    Registered Bob La Londe's Avatar
    Oct 2008
    I am working on an idea that involves a guide rod (3 actually) sliding back
    and forth in a "bushing" with some degree of accuracy. Actually the guide
    rod would be in two different bushings about 2.75 inches apart. Side load
    would be very light, but there would be some. (less than inch pounds in
    most cases) During the course of use the guide rod might have to move 0.050
    40-50 times, and have continuous movement from .001 to .009 for a 20 minute
    job.
    Some small amount of side play would be tolerable but experimentation is
    required to determine how much. Greater for some jobs. The idea is that
    the bushing can be pressed out and replaced periodically as needed.
    1. If you were to do this ideally what would you use for the bushing and
    the guide rod?
    2. If the ideal materials where not available what would you use that is
    commonly available?
    3. What would you use that is commonly available and cheap?
    Due to space limitations I am looking at a guide rod diameter of
    approximately .25, but I could redesign for up to .375. Extra mass could
    have a negative impact on the intended direction of travel, but mass could
    be removed elsewhere.
    I was thinking of something like this for the bushing. The guide rod will
    be fixed and not rotate in the bushing. Just slide back and forth. The
    guide rod will be vertical. Side load (minimal) will be in any and all
    directions at one time or another.
    http://tinyurl.com/yjub9ak
    And something like this for the guide rod.
    http://tinyurl.com/yzhmvlm
    I would add that the over tool body would be aluminum (for weight) and the
    guide rod would be fixed into the carriage or moving part of the tool
    directly either by a press fit or possible with green Loctite bushing and
    sleeve locker. This would make a stainless alloy for the guide rod
    desirable.
    Bob La Londe
    http://www.YumaBassMan.com
    Jul 2005
    I doubt you could come up with anything better than you are thinking about, sintered bronze bushings and hard stainless rods.
    You will have to be very careful to get the holes you press the bushings into parallel and concentric and use a threaded rod with some washers to pull the bushings into place so they go in straight. Also you will have to make sure the fit on the bushings is not to tight so they do not compress down too small for the rod; it is difficult to ream these bushings to size.
    Oct 2008
    Quote Originally Posted by Geof View Post
    Makes sense. How about a very easy press fit for the bushings and locking them in with sleeve locker like with the rods in the other part?
    I fgured I would mill a sacrificial wood block perfectly flat epoxy my aluminum blocks in place on the wood block, and then use my CNC mill to drill all my holes. With what I have I do not see how I could do it any more accurately.
    I can even mill a guide lip or fence on the wood block so I only have to adjust in one direction for zero from one piece to the next.
    Had also considered stacking all my blanks and drilling each hole through all pieces at once but I fear due to the varience in plate thickness I could wind up with more inaccuracy that way and a likelihood to not be parrallel.
    I figure I will get the best repeatability if I take my mill back to 0,0 relative to the piece before positioning to drill each hole.
    Bob La Londe
  1. Anyone use a spring-loaded engraving tool?
    By laka in forum General Metalwork Discussion
    Last Post: 01-07-2009, 11:09 PM
  2. 14.77 Spring Loaded Engraver
    By fretsman in forum Engraving Machines
    Last Post: 04-28-2008, 08:21 PM
  3. Spring loaded graver drawing
    By fatal-exception in forum Engraving Machines
    Last Post: 04-20-2008, 08:24 PM
  4. THC Floating head needs to be spring loaded?
    By Normsthename in forum General Waterjet
    Last Post: 12-12-2007, 08:44 AM
  5. spring loaded rack and pinion
    By dgalaxy in forum General Waterjet
    Last Post: 12-03-2006, 12:49 PM
