Results 1 to 4 of 4
Thread: Need vacuum hold down solution
    *Registered User*
    Feb 2006
    us
    Shown in the pics:
    3- solid plexi 4 x 6.6
    1-laser routed 4 x 6.6 with slots for air
    1-(white) rubber gasket
    1-1/8" glass to be held down
    I intend to glue the 4 plexi parts together, and mount those on a .5" base of aluminum or plastic. The plexi mini-vacuum table will get a hole drilled in it from beneath, and a .25" copper tube attached.
    Where I am stuck is by what method to vacuum the air out. The cheapest, simplest, fastest solution is required. The glass will be slightly covered in diamond cutting lubricant(water and solution). The glass breaks wqhenm I try to clamp it, and since I am routing the perimeter and drilling/milling the glass, there cannot be a clamp anyway.
    Any suggestions for a powerful suction but simple system would be appreciated.
    Current ideas:
    refrigerator motor
    rigged bicycle pump
    pvc or aluminum 1" tube with home made rubber plunger and threaded rod to pull the plunger through the tube to create vacuum.
    Attached Thumbnails Attached Thumbnails Need vacuum hold down solution-1.jpg   Need vacuum hold down solution-2.jpg   Need vacuum hold down solution-3.jpg
    Jan 2008
    Check local state and university surplus outlets for a vacuum pump, also check ebay.
    Lowell
    Aug 2008
    originator
    Here is a link to joewoodworker, I picked up parts from them to built a vacuum press so I could build composite radio controlled aircraft. I built a vacuum rig like they show on the site. I works awesome and wasn't too expensive. I'm getting ready to build a vacuum table for my mill and use this rig.
    Larry O
    *Registered User*
    Feb 2006
    us
    Thanks guys. I bought a used vacuum pump 3/4 hp that tested at 12 microns. Seems like it will do the job, setting it up now.
  1. hold down vacuum system
    By alfonsonog in forum DIY CNC Router Table Machines
    Last Post: 02-10-2008, 02:11 PM
  2. Vacuum Hold down for wood.
    By HomeCNC in forum DIY CNC Router Table Machines
    Last Post: 07-24-2007, 12:16 AM
  3. 4x8 Vacuum Hold Down
    By elogicca in forum DIY CNC Router Table Machines
    Last Post: 07-23-2007, 09:06 PM
  4. Hold-Down Solution for Taig
    By Burn in forum Work Fixtures and Hold-Down Solutions
    Last Post: 03-31-2007, 05:54 AM
  5. Hold Down solution question?
    By GalaticDan in forum DIY CNC Router Table Machines
    Last Post: 11-25-2006, 08:22 AM
