Make a split bushing out of steel.
Have a small flange on each end so that the chuck jaws fit between the flanges to stop it sliding out of the chuck when you push the rod through.
Bore the hole for the rod about .005" oversize because when you cut the split it will probably close up a little.
LinkBack URL
About LinkBacks
