Page 1 of 2 12 LastLast
Results 1 to 12 of 21
Thread: machining through breaking end mills
    Dec 2007
    Unhappy machining through breaking end mills
    I have a part that i am cutting with A carbide 1/8 dia. end mill 2 flute 3/4 loc through 5/8 6061 alum. Problem is no matter how i hold it if on a tool plate or in a vise .I am breaking end mills on the final pass may cut out two or three and then one will cock and bind and snap goes the wiesel .Any one have an idea how to elimanate this problem? Thanks
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Question
    Woffler,
    What is your DOC, spindle speed and feed rate?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Dec 2007
    Spindle speed 1750 feed rate 3ipm doc .15
    Feb 2007
    U.S.A.
    Post
    Woffler,
    I neglected to ask what step over you are using?
    Your spindle speed seems very slow for what you are cutting.
    Jeff...
    Feb 2007
    U.S.A.
    Post
    Your depth of cut is three times to much by the way, try 1/3 the diameter of your tool.
    Jun 2006
    CRANK THE SPINDLE UP TOO MORE THEN 3000, GO EASIER ON THE DOC MAYBE .020, SPEED UP THE IPM BETWEEN 15 OR 30, AND FLOOD THE LITTLE SUCKER COOLANT IS IMPORTANT. IN GENERAL KEEP THE CHIPS SMALL ON TINY FLUTED END MILLS
    Feb 2007
    U.S.A.
    Aug 2005
    I think woffler is saying that on the final pass the PART will move and jamb the cutter against the aluminum plate just as it seperates from the plate.
    If this is the case you need to add bridges to hold the part, or secure it in another way before the full profile is cut. If the part has a hole in the design, you can machine all the parts except for the final pass, then pause and run a bolt through each hole and then make the final separation cut. I'm sure others will chime in with more methods.
    Dec 2007
    Thanks to everyone for responding The speed is limited to 1970 rpm and you are right it is on the last cut that it jams aginst the plate .I will boost rpm all the way up and i am looking for a faster motor to get my spindle speed up geared head mill .I am using full flood cooling i will will reduce my depth of cut and make more passes there are no holes to anchor the part .The part looks like a long shaft with a hook on one end only .125 wide and 4.0 long lots of room for vibration on final bottom pass .
    Feb 2007
    U.S.A.
    Smile
    Woffler,
    Post a picture of the part, maybe someone will have a solution.
    Jeff...
    Dec 2006
    A picture would be priceless. I strongly suspect the slot is closing up and pinching the endmill on the final cut.
    Registered LeeWay's Avatar
    Jun 2004
    On my steel sheet parts, I leave tabs or just a little foil under the cut. IOW, leave out the very last breakthrough pass. I then just bust them out with a bandsaw. It does need a little deburring afterward, but don't have any movement of the fixtured part.
    Lee
  • Page 1 of 2 12 LastLast
    1. Need Help!- breaking taps!!!!!
      By dieman1968 in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 04-01-2009, 05:06 PM
    2. Problem- Breaking 6-32 taps
      By CNCMike in forum General Metalwork Discussion
      Last Post: 12-05-2008, 04:27 PM
    3. gun drills keep breaking!
      By slidingheadfred in forum General Metalwork Discussion
      Last Post: 11-15-2008, 12:20 PM
    4. Face Mills intstead of end mills
      By balal in forum General Metalwork Discussion
      Last Post: 07-01-2006, 01:35 AM
    5. i keep on breaking bits???
      By joeyboy in forum General Metal Working Machines
      Last Post: 03-24-2004, 04:18 AM
