one good way to machine plastics is to use what is commonly reffered to as double sided tape....it is sticky on both sides...clean your table with alchohol or acetone.or something of the like,then stick the tape down to the table,peel off the backing on the top side of the double stick tape and clean the surface you intend to stick down on the tape with alchohol as long as your table is flat and you dont get to wild with cutting you can do pretty well flycutting with sharp tools ,in case you didnt know cleaning with alchohol will remove all the oil that may be on you table or part...so the tape will stick well .
again be easy with it at first..till you see how well it will hold...some times you can reuse the tape...but in most cases its best to just roll out some more as its cheaper than a new part if the tape turns loose...hope this helps...
LinkBack URL
About LinkBacks
