let me re-clarify my earlier novice hint. That only works if ya have enough parallels running under your work piece. I soon found out that I was wrong in assuming there was no way I could cause 3/4 steel to bend by tightning clamps but ya can by as much as .008. So I spent most of the day correcting that. Also in the process I learned that for finishing cuts on steel it seemed like a 2 flute did better than the 4 flute( which is wierd becuz everyone says 2 flutes for aluminum and 4 flutes for steel) However in the end I ended up using 4 flutes. Anyway I would have grabbed some pics but I was so exhuasted after I was done today on just the base the vice that I couldn,t muster the energy to snap some pics. I,ll do it tomorrow when I got a real precision work piece to show off.
LinkBack URL
About LinkBacks
