Hello,
Vacuum pump of my Home CN, controlled by a vacuostat, and an electric relay 12volts, allowing to define a threshold and hysteresis.
The threshold = maximum level of the vacuum to be created, from which the power supply of the pump will be stopped.
Mini Hysteresis = level of vacuum from which the power supply of the pump will be to reactivate, in order to maintain a vacuum sufficient for the good behavior of the part which is with machining.
Video :
http://www.youtube.com/watch?v=TgnJMBGRxHg&feature=plcp&context=C3f9d159UDOEgsToPDskJMpZ98fMJdjVE7NWqQ_tks]Pompe-Vacuostat-Hysteresis.wmv - YouTube
Favors: the vacuum pump does not turn continuously...
Lastly, below an image of my connections (of concrete, not technical of the whole, I recall that I am cabinetmaker… and not electrician).
http://www.cnczone.com/forums/attach...1&d=1328549211
To visit my chain “youtube”:
http://www.youtube.com/user/FXL126/videos
@+FXL126
If you have other electronics close by it is customary to put a reverse EMF diode across the coil, a 1n4005 or equivalent, the cathode (stripe) goes to positive.
