Page 1 of 2 12 LastLast
Results 1 to 12 of 22
Thread: Fixturing a tapered part with compound angles on both ends
    JAW
    JAW is offline
    Jun 2011
    I am cutting a part that is round to rectangular with compound angles on both ends. The setup for this is no problem until I get to the final compound angle. If you have any ideas on the final setup I'd appreciate it.
    I've attached a sample file of what I am doing with the multiple setups and final part.
    Attached Files Attached Files
    hub
    hub is offline
    Sep 2010
    Finland
    Leave some rest material for the last step maybe and fix it to an angle plate?
    ** EDIT**
    The taper would be the other way around, bigger towards the rest material..
    Attached Thumbnails Attached Thumbnails Fixturing a tapered part with compound angles on both ends-untitled-1.jpg
    http://www.cnczone.com/forums/cnc_wood_router_project_log/125895-my_diy_cnc_cnc2011_%3B.html
    Jan 2009
    Ball end mill
    Quote Originally Posted by hub View Post
    You will have to cut the last part with a ball end mill or a tapered mill.
    JAW
    JAW is offline
    Jun 2011
    In this pic the green parts are extra material where I will clamp on to it with machinable jaws. The big square end will be milled down to remove the excess stock, then I can easily mill the compound angle for that end. Once that is done the small rectangular end will be milled down and that end will receive a compound angle too.
    The second pic shows the final part straight on at front, right and back view.
    Attached Thumbnails Attached Thumbnails Fixturing a tapered part with compound angles on both ends-part.jpg   Fixturing a tapered part with compound angles on both ends-part_2.jpg
    hub
    hub is offline
    Sep 2010
    Finland
    Quote Originally Posted by JAW View Post
    Yes, that would work I think
    JAW
    JAW is offline
    Jun 2011
    What I am trying to figure out, is how to hold it, so I can mill the small end and cut the compound angle because this will be all that is left
    Attached Thumbnails Attached Thumbnails Fixturing a tapered part with compound angles on both ends-part_3.jpg
    hub
    hub is offline
    Sep 2010
    Finland
    I'm assuming you are doing this with a 5+ axis?
    So, I would leave enough stock to fix it for the last operation. And the last would be to cut the part off the rest material. Maybe I'm not understanding correctly.. What machine are you using?
    Jan 2009
    jig
    if the whole part is tapered then mill the small end of the cone first. Cut a mold the small end will fit in. Put some side setscrews or clamps. then mill the large side.
    JAW
    JAW is offline
    Jun 2011
    I would prefer to keep this 3 axis if possible. I may have to look at doing this in 5. I am working with a Haas ES-5-4T, horizontal mill.
    JAW
    JAW is offline
    Jun 2011
    Quote Originally Posted by job_it View Post
    I think that may work!
    hub
    hub is offline
    Sep 2010
    Finland
    OK..
    In my opinion that part would be difficult to make on a 3 axis. Because there are internal & external tapers.
    But MAYBE, do the internal taper first (through the rest material). Then, flip the part and do the external taper & facing. Then fix the part 90deg & cut off the part from the rest material..
    Jan 2009
    Jig
    You just have to make sure the part doesn't rotate. your mill will provide the down pressure. I would use a .75 or 1" plate and mill a segment up the part a straight cut will be fine. . If you are milling alu. then place wood or plastic on edges where it makes contact on the walls of your cone shape
  • Page 1 of 2 12 LastLast
    1. Help figuring out the angles
      By Shanghyd in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 04-14-2010, 12:15 AM
    2. Multi-Part Fixturing
      By Geof in forum Work Fixtures and Hold-Down Solutions
      Last Post: 10-09-2009, 09:25 AM
    3. Need Help horizontal part lots of angles
      By chuy in forum Mastercam
      Last Post: 01-11-2008, 05:29 PM
    4. Help Modeling a Part w/ Complex angles
      By nlh in forum Alibre Design
      Last Post: 09-20-2007, 05:31 PM
    5. Enco Compound Slide Milling & Compound Drilling Table
      By 7ofclubs in forum DIY CNC Router Table Machines
      Last Post: 12-23-2006, 11:43 PM
