Results 1 to 7 of 7
Thread: Holding a block for facing
    Registered Mihelich's Avatar
    Apr 2009
    Hey guys,
    I am running into an issue in trying to figure our how I can hold down a block of aluminum to my CNC table for facing of the surfaces.
    With the block needing to be faced on all sides, I cannot drill holes into it for a hold down nor can I clamp down on the top of it as that is the surface I would be trying to face.
    How in the heck would I hold something like this to the table for a facing operation??
    May 2006
    It would be best to describe how big a billet, etc. depth of cut,
    The Push Clamp
    Push clamps are designed to put a large amount of pressure
    against (X,Y) the piece on which you are working .
    Been doing this too long
    May 2004
    You did not say what kind of machine or any other specifics such as how much Z height or clearance you have. Toe clamps (push clamps) can work, but they usually require that you have T-slots to mount them or you have to drill and tap mounting holes in your table. You can work around that buy putting a sub-plate on your table with regular clamps and drilling and tapping mounting holes in that. Vacuum is an option. Double face tape is an option. Mounting a vise to your table and using that is an option.
    http://www.kirkcon.com/
    hub
    hub is offline
    Sep 2010
    Finland
    Quote Originally Posted by Mihelich View Post
    Hey guys,
    Machining vice? One side at a time..
    http://www.cnczone.com/forums/cnc_wood_router_project_log/125895-my_diy_cnc_cnc2011_%3B.html
    Registered Shane123's Avatar
    Jul 2010
    i know this might sound weird at first, but why not cut it an inch per side, and then countersink and drill some holes in that "extra material" to hold it down to the table..... even just 2 sides will work. then on your opposite side, you can run the mill down to cut those flaps almost off (leave a 1/16" or so) when you get done facing the big portions.
    we do it all the time to uhmw since it likes to flex when side clamped. works like a champ!
    Sep 2007
    There are many ways to hold a block for facing.
    1 If size permits use a mill vise. Large items use a two piece mill vise.
    2 larger objects you can use edge clamps Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
    3 c clamp to an angle block.
    Hope that helps
  7. #7
    Mar 2010
    hell
    hold in a mill vise on .05 material
    machine five sides
    flip over material set on parralles machine sixth side to thickness
  1. Need Help!- Facing lead in...
    By Jason3 in forum MadCAM
    Last Post: 05-06-2010, 07:03 AM
  2. Need Help!- V23 problem with facing
    By mbam in forum BobCad-Cam
    Last Post: 06-04-2009, 09:34 PM
  3. Need Help!- V22 Facing ?'s
    By bink in forum BobCad-Cam
    Last Post: 02-15-2009, 06:22 PM
  4. Facing
    By impact in forum General Metalwork Discussion
    Last Post: 02-22-2006, 09:24 PM
  5. RS232 program block by block
    By smoregrava in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 12-22-2005, 01:52 AM
