A Cam-lock level mechanism against the shaft you are trying to lock would probably serve you better, since a thumbscrew will eventually chew up the shaft. Some wear will also occur using a Cam lock, if excessive forced is used to close the lock. However, Cam-locks work very well, if you are able to also utilize a flat plate onto the shaft, against which the cam-lock is applied. (Think Disc Brakes on your car).
LinkBack URL
About LinkBacks
