Would something like this work for you? McMaster-Carr
I am looking for a precision tolerance strap clamp similar to this:
https://sdp-si.com/ss/gif/SSGCAJ.JPG
I can only find them in .250 ID at the above source and I need 3/4 to 7/8 id range.
Can anyone point me in the right direction?
Thanks.
Thanks packrat,
It would work but I was really looking for something that is one piece that could be removed by hand – no tools - that I could use without set screws I was thinking more along the lines of putting a big thumb screw on my clamp for quick release from tubing - the clamp is for a little jig I am designing and I want to make it easy for the user to remove it quickly. So in that first pic I posted it would be easy to put a thumb wheel screw or something like that on it...
Nadsab,
You might be able to use something like this (it's a quick release bicycle seat post clamp): Woodman Deathgrip QR Seat Clamp at JensonUSA.com. If that didn't work there are similar ones used to clamp the bicycle wheel. You would need to modify the length on those.
[IMG]//http://www.jensonusa.com/store/product/QR295B04-Woodman+Deathgrip+Qr+Seat+Clamp.aspx#[/IMG]
Thanks mmcleod I'll check it out.
For some reason the wrong link was postedThis is the one I wanted;
McMaster-Carr They use a cap screww that can be replaced with a thumb-screw.
