Clean both surfaces to a water break then with precision, bond the parts to a substantial sub base with the glassy hard curing polymer of your choice. Clamp conventionally, mill, inspect, and demount with heat and/or with judicious encouragement, the part is released. This method is not new nor is it such a secret that some will wish it to be. In a jam, the use of JB weld for heavier parts with no clamp surfaces will do - no problem with proper cure. JB will go to 500f or so to soften to a release and is not glassy hard as is desirable for this type of fixturing adhesive. A sharp blow in a vulnerable spot will release most parts, and the remains can be ground, scraped, polished or aerosol spray paint removal - removed. Polyester resin works but the parts must be CLEAN
Bill
LinkBack URL
About LinkBacks
