Results 1 to 4 of 4
Thread: SUB Plate holding
    Jan 2007
    SUB Plate holding
    I have a h210 4th that I am building a tombstone for..
    I want to put sub plates on the tombstone.
    IE load them on the bench while other parts are running.
    a long time ago Like in the mid 90's I used some bolts that turned one turn and locked in. I cant seem to find them now.
    The plate has dowel pins to locate on the tombstone. just trying to find some hardware that will lock the plates down to the tombstone thats quick and easy and holds tight. Yes I could use 1/2-13 bolts but that defeats the purpose I need to run 50 plates per side IE 200 at a time
    The tombstone is made out of alum its 23 inches long 6.0" wide, Then I have alum subplates 5/8" thick, I could go 3/4" thick if I have to but thats pushing the limit on z travel and table clearance to bottom of the 4th axis
    I have a "A" frame for the support end.
    Delw
    Jul 2005
    "Ball Lock"???
    Does that ring a bell?
    I vaguely recall seeing a systen for clamping fixture plates that used a pin with three balls sticking partway out of holes with a tapered screw inside that locked them out. They fitted in hardened inserts which had a groove the balls enterd to pull the pin down.
    Jan 2007
    Thats it, I saw that last night after I posted in another thread just above this one.
    the company was carr lane. only thing I dont remember paying 125 bucks for each ball lock lol
    Registered Cmailco's Avatar
    Aug 2010
    Arrow
    Jergens is another supplier and I believe, hold the original patent on "Ball-lock" systems. Expensive yes... at least till you calculate the ROI.
    http://www.jergensinc.com/site/wsg_q...ange_fixturing
    Best of luck.
    The Manufacturing Reliquary
    http://cmailco.wordpress.com/
  1. Any tips for designing a fixture plate / tooling plate?
    By thackman in forum Benchtop Machines
    Last Post: 12-19-2008, 12:26 PM
  2. 59 Oz holding torque?
    By Chalkbot in forum Stepper Motors and Drives
    Last Post: 07-25-2008, 07:48 PM
  3. Aluminum: flat, bar, sheet, plate, tooling plate??????????
    By Dan S in forum DIY CNC Router Table Machines
    Last Post: 06-28-2007, 01:48 AM
  4. PCB holding for thru holes
    By yugami in forum Work Fixtures and Hold-Down Solutions
    Last Post: 10-20-2006, 10:10 AM
  5. Tooling plate or sub-plate
    By drill in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 02-02-2006, 03:17 PM
