Results 1 to 8 of 8
Thread: MACHINING A ROCKER CLAMPS
    Registered backyard_cnc's Avatar
    Mar 2008
    Hey everybody,
    Please check out my you tube video on CNC machining a milling table/fixture plate rocker clamp! Comments welcome.
    Cheers
    Gerald
    [nomedia="http://www.youtube.com/watch?v=a8UWA2LWW4Q"]YouTube- CNC MACHINING OF A ROCKER CLAMP FOR A MILLING MACHINE[/nomedia]
    Apr 2008
    Good video. And no, you're not talking to much, it's nice to hear what's you have going on.
    Trenton
    Registered HelicopterJohn's Avatar
    Dec 2005
    Seffner, Florida USA
    Nice Work
    Hi Gerald,
    Looks like you are having a ton of fun.
    I am retired and have a HAAS Toolroom Mill and make parts for the Radio Controlled Model Helicopter/Airplane Hobby.
    I too have a bunch a friends that always need that little project done for them.
    Keep up the good work.
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://www.helicopterjohn.com/
    Mar 2008
    Thanks for the nice comments gentlemen, nice to know some people have enjoyed the video. Unfortunately haven't been getting much CNC shop time of late so no new video to post, soon I hope !
    John, I am envious of your HAAS TM-1P. I hope to put one in my shop at some point when it all starts to make a little cash flow to justify the write off. I think the TM and TL products are excellent choices for a guy in a home shop since they readily use single phase power. Be interested in any comments you might make about the HAAS. I have used the MINI MILLS and SUPER MINI's but no time at all on a TM. Controls are the same the and the HAAS controller is easy to navigate. Feel free to PM me on the HAAS.
    Cheers
    Gerald
    Feb 2010
    Clamp Assembly
    How are the sides of the clamp fixed to the two steel round parts on each end? I can't see any screws so I assume they are press fit into the holes on the side plates?
    Mar 2008
    Yes they can be held together with a slight press fit pin or if the pin is lose you can use a punch to peen each end to make it tight or you could use a nut and bolt but I like the look of pins over the nut/bolt approach. It is a neat and useful project.
    good luck
    Jul 2011
    Thumbs up Nice
    Sort of like some of the Lenzkes system clamps Lenzkes Clamping Tools Inc - Christiansburg, VA
    Feb 2010
    Thanks for the reply. So are those steel parts are actually two piece, (collar with a pin through the middle)? I had thought that they were made from one piece of round stock with both ends machined down to fit into the side plate holes.
    1. Need Help!- What kind of clamps should I use?
      By woox in forum DIY CNC Router Table Machines
      Last Post: 01-07-2011, 12:42 PM
    2. Need Help!- Wiring an Illuminated Rocker Switch
      By blue_steel in forum General Electronics Discussion
      Last Post: 03-22-2009, 08:33 PM
    3. Clamps
      By majstor76 in forum CNC Machining Centers
      Last Post: 12-16-2008, 09:47 AM
    4. Material for Rocker Shafts
      By Alex Westling in forum General Metalwork Discussion
      Last Post: 01-23-2008, 01:42 PM
    5. Machining an aluminum rocker arm for pulling tractor
      By jpcuttergrinder in forum General Metalwork Discussion
      Last Post: 02-12-2007, 05:39 PM
