Milling vise or vaccume table
Results 1 to 5 of 5
Thread: Milling vise or vaccume table
    Sep 2016
    Default Milling vise or vaccume table
    Assuming I can only buy one of the above, what would be more useful assuming I plan to mill mostly aluminium for my hobby projects.
    Jan 2005
    Default Re: Milling vise or vaccume table
    Mostly aluminum what? Bar stock, thin sheet, thick plates, aluminum extrusions, round stock.....
    Sep 2016
    Quote Originally Posted by 109jb View Post
    Bar stock, thin sheet, thick plates mostly..
    Member dharmic's Avatar
    May 2015
    Horses for courses.
    Vacuum table isn't going to help much with bar or round stock, or extrusions which don't have significant surface area. You're going to want the vise or some other clamping system for those. The vac table is great for thin sheet though, without it you're looking at gluing the stock down to a thicker spoilboard which you can then clamp down.
    Dec 2013
    Why not buy the vice and make a vacuum table, you really need both. Pretty easy to make vacuum tables. Double sided tape works well for some things also.
