question about tailstock for millturn mill
Results 1 to 4 of 4
Thread: question about tailstock for millturn mill
    Default question about tailstock for millturn mill
    hello all,
    shortly i machined a gang block for turning on the lathe. i want to machine motocycle handles in aluminium, 150mm long, 40mm diameter. unfortunately i get a lot of instability in the part when getting aaway from the spindle since the part is not supported with a tailstock. the first 50mm are fine, then it starts with bad surface and chatter. i was going very slow with the feedrates.
    i was thinking of making a kind of tailstock that could be clamped to the z axis and would support the part with an m8 screw from the bottom. i dont need best precision, but it should machine smoothely.
    i sketched a tailstock in fusion. since i am not so experienced with this stuff i wanted to ask whether this could be a solution? would this prevent chatter? i would machine this part out of steel, 15mm thick. the total length would be like 300mm.
    sorry the first 3 pictures are turned 90° to the left. linux behaves sometimes strange ,-)
    thanks for any help,
    have a good new year 2017,
    michael
    Attached Thumbnails Attached Thumbnails question about  tailstock for millturn mill-img_5589-jpg   question about  tailstock for millturn mill-img_5590-jpg   question about  tailstock for millturn mill-img_5591-jpg   question about  tailstock for millturn mill-img_5592-jpg
    question about  tailstock for millturn mill-img_5593-jpg   question about  tailstock for millturn mill-reitstock-jpg
    Default Re: question about tailstock for millturn mill
    i would really appreciate some help on this topic. i added more detail to the model, maybe it is now clearer. there would be no need to adjust the lenght of the tailstock, an the stock would be 150mm ( about 5") long, 40mm (1,75") diameter.
    thanks for your input,
    michael
    Attached Thumbnails Attached Thumbnails question about  tailstock for millturn mill-millturn-reitstock2-jpg
    Apr 2014
    Unsupported work will almost always chatter to a certain degree ,you could use a kind of sacrificial cup at the end ,in the past I have made a few different shapes that have a small bearing in the opposite end then turned a shape to fit the work piece .Made out of nylon delrin usually even hard wood I remember good luck .
    Default finished tailstock for millturn mill
    hello,
    i just finished the tailsock for millturn, and it works it is made from steel, with a bearing in which the center tip is. there is a little chatter because the tool is sticking out too much. if i press my finger on it it is more quiet. if you like to see, here is a little video: https://www.dropbox.com/s/038o29h1td...turn1.mp4?dl=0
    i am using msm millturn, the tool change also works.
    here are some photos, sorry for the wrong direction, my linux does not want as i want it to.
    michael
    Attached Thumbnails Attached Thumbnails question about  tailstock for millturn mill-img_5698-jpg   question about  tailstock for millturn mill-img_5696-jpg   question about  tailstock for millturn mill-img_5694-jpg   question about  tailstock for millturn mill-img_5700-jpg
