Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: How to use 1/8" bits in my 1/4" bore router?
    Oct 2005
    Hi, I asked this question in the "Wanted to buy" section of the forum, but didn't get a good solution yet. I'm reposting it here in the hope that someone will have an answer, I hope that is ok.
    My router is an Australian brand small router with 1/4" bore. I have 1/4" tools but I also have a lot of Dremel etc 1/8" specialty bits. These measure in shank size from about 3.05mm to 3.30mm, I guess the 1/8" is a bit relaxed with some manufacturers.
    Is there an easy/cheap solution to allow me to use these 1/8" bits in my 1/4" router? The collet in my router is about an inch long and has a tapered section on the front third of it's length.
    Something that would be ideal (to my mind) would be like a little Dremel chuck that could take the 1/8" bits (and even 3/32" bits) and the rear of the chuck would be 1/4" to slide straight in my router.
    So if anyone knows a solution like that, or can recommend something that would work please let me know.
    Jan 2009
    4486 Dremel Keyless Chuck
    Quote Originally Posted by RomanLini View Post
    Try the 4486 Dremel Keyless Chuck. It replaces the regular chuck on dremel tools but I am sure you could make an adaptor to allow you to mount it on a 1/4 inch router.
    Registered SanDiegoCNC's Avatar
    Jan 2005
    Good luck finding an adapter. The wall thickness would be no more than 0.060 . I'm betting you'll either have to machine a bushing... not a collet, or make a whole new mandrel that will accommodate your smaller tooling. Just out of curiosity, what target price are you willing to pay for a bushing/arbor or a new mandrel?
    May 2007
    Have you called the manufacturer to find out if they have different sized collets?
    Look like any of these?
    http://gpcollets.com/allProducts.html
    And some adaptors.
    http://gpcollets.com/adapter_cross.html
    Feb 2009
    Quote Originally Posted by SanDiegoCNC View Post
    How 'bout this?
    http://www.mcpii.com/Nicknacks.html#anchor_96
    Oct 2005
    Thanks for the info guys.
    Andre'B- I checked that web page for collets and adaptors, none of the collets look exactly like the one in my router. I've posted it's collet dimensions in the thread in the wanted part of the forum, hopefully precise bits will get back to me with some more info if they have a compatible unit.
    Apart from that it's in limbo at the moment. I might lathe up a brass version of my collet that has a 1/8" bore and a 3/32" bore to hold the 2 main sizes of Dremel bits, the good HSS bits have good shank diameter tolerance and the dodgy 1/8" sizes are mainly aftermarket bits like diamond bits and some burrs etc.
    I'm still thinking about cutting the shaft out of a Dremel type tool and cutting off the last 1.5" that has the dremel collet chuck and turning the shaft down to 1/4". That would be good as I have a range of tiny Dremel collets going down to PCB drill size, so functionally it would be like putting the Dremel in my router.
    Jan 2005
    I'd be quite careful doing this. Routers run at high RPMs.You need to indicate the shaft withing a few tenths or its going to vibrate at high speed. That vibration can lead to all sorts of nasty things happening to you or your machine tool.
    Be aware that you will need to machine a few thousandths at a time on your OD and watch for tool deflection on the shaft. I'd go for a very sharp insert tool when machining the shaft... perhaps a CNGP43.0 (0.007R) or an NPR (0.004R) insert. Keep the OAL short. Just a few tips should you decide to go this route.
    Aug 2005
    I'm using a 1/4" to 1/8" adapter made by Rotozip for their Rotozip tool. It's inexpensive, well made, and is rated for high rpm. The cutter is secured by an allen set screw and the 1/8" cutter is a snug fit in the bore of the adapter. I did not see any negatives when using it for what that's worth.
    Jun 2006
    This is what I did. Hope it helps.
    http://www.millerwelds.com/resources...ghlight=collet
    Nick http://www.nixstuff.com
    http://www.youtube.com/watch?v=jTu7wicVCmQ
    Oct 2005
    Thanks SanDiego, I still think a Dremel chuck would be ok if I can make sure it has low runout and is mounted close to the router nut.
    monte55- I ended up making 2 adaptors for now, quite similar to yours. One is 3/32" and one is 1/8" so they can do most of my better Dremel bits.
    I used some 1/4" aluminium rivets that were in my junkbox, and trued them and drilled them. Then they are slotted totally on one side, and for 3/4 of their length on the other side (also like your adaptor! Great minds think alike haha). Because they only have a very small skin holding them they conform well to both the bit and the router bore. Maybe the soft alloy helps there too.
    My dial gauge easily measures the 0.0003 runout of my lathe, and these were made at zero runout (past the limits of my dial gauge) and they maintain this even in the router.
    I cut some very fine engraving today with the small bit, it was holding a .003 line easily.
    Thanks again everyone, for the moment I am right for 3/32" and 1/8" adaptors. I would still like a Dremel collet chuck though to use my range of Dremel collets and for things like PCB bits and non standard 1/8" shank diameters.
    Attached Thumbnails Attached Thumbnails How to use 1/8" bits in my 1/4" bore router?-aut14952.jpg
    Registered Walky's Avatar
    Jul 2009
    Chile
    If someone finds this useful, I've been using this adapter and it has served me well:
    http://cgi.ebay.com/ADAPTOR-CHUCK-AD...item518d845824
    Very low runout (unnoticeable by eye), enough for SMD. The thread is very strong, and 1/8" tools fit very tightly in the adapter (sometimes a little too much, I need to use pliers to get some tools out sometimes). I broke one of the internal collets once (my mistake, shame on me), and bought a new one and a spare just in case: the runout is still very low
    I've cut wood (2-3mm doc) and aluminum with it (~ 0.15 DOC). The smaller collet fits dentist's tools, which is nice.
    Here's a video I made using this adapter:
    [nomedia="http://www.youtube.com/watch?v=oM2acy0VPrA"]YouTube- ‪Grabado de PCB en fresadora CNC‬‎[/nomedia]
    Mar 2003
    Shelby Twp, MI....USA
    Didn't realize this was an old post, but you can also use these.
    http://www.mlcswoodworking.com/shops..._bearings.html
  • Page 1 of 2 12 LastLast
    1. "low end" HF Spindle or "high end" router for about $1000?
      By biomed_eng in forum DIY CNC Router Table Machines
      Last Post: 01-06-2012, 01:15 AM
    2. Adaptor for 1/8" bit in 1/4" inch router bore
      By RomanLini in forum Want To Buy...Need help!
      Last Post: 02-23-2010, 03:18 PM
    3. Replies: 0
      Last Post: 10-28-2009, 01:30 AM
    4. where do I get 60 degree "V" Router Bits
      By tdnp in forum WoodWorking
      Last Post: 01-10-2008, 03:13 PM
    5. Boss 6 Motor Pulley Options - 5/8" to 1/2" Bore
      By snakebit95 in forum Bridgeport and Hardinge Mills
      Last Post: 08-11-2006, 03:03 PM
