Results 1 to 5 of 5
Thread: Dremel Router bits
    Mar 2008
    Dremel Router bits
    Hello - I have just finished building the Solsylva 13X13 machine and it is working great (so far). It sports a Dremel for the router. However, I don't know what type of bit I should use for general carving in wood. Also, any suggestions on the speed settings would be appreciated too. Thanks!
    Jan 2009
    Dremel
    What model of Dremel are you using. Dremel makes several models. For general engraving on wood, I use a 60 degree engraving bit. It has a 1/4 inch shaft.
    Mar 2008
    The one I have mounted at this time is a Craftsman Rotary Tool, model 572.610031, and I also have a Dremel MultiPro 395. Both (interchangeably) accept only 1/8th inch shaft tools.
    I was looking yesterday at sprial router bits, but the smallest shaft dia I could find was 1/4 inch. Is there any type of adapter that would allow 1/4 inch shafts to be used?
    Mar 2003
    Shelby Twp, MI....USA
    No, but you can get 1/8" shank endmills on Ebay for cheap.
    Feb 2009
    Quote Originally Posted by ger21 View Post
    Very nice bits available here: http://www.precisebits.com/
    Also, I would suggest you move away from the Dremel/Multi-tool route. These devices are not very precise. You will be able to get MUCH better performance from a trim router, something like the Bosch Colt is a good suggestion. These also support 1/4" bits, and Precise Bits makes a 1/8" collet for it as well.
    1. Router or dremel?
      By posix in forum DIY CNC Router Table Machines
      Last Post: 05-21-2012, 04:43 AM
    2. Router bits, End mills v bits
      By bogger44 in forum Commercial CNC Wood Routers
      Last Post: 12-03-2008, 01:06 PM
    3. place to buy dremel cutting bits?
      By woox in forum CNCzone Club House
      Last Post: 09-13-2008, 09:32 PM
    4. How many people use their dremel for their DIY router?
      By studysession in forum DIY CNC Router Table Machines
      Last Post: 08-24-2006, 02:04 PM
    5. Using Dremel 3/16" Bits In My MaxNC
      By roys29 in forum Benchtop Machines
      Last Post: 12-12-2005, 09:59 AM
