If you know anyone with a metal lathe, you can have a simple reducer made to take a smaller diameter shank that will fit your router. This would be a 1/4 rod drilled with whatever size cutter shank you would like to use. Then split along the length with a hacksaw.
engraving supplies at Mississauga ON
Canadian Engravers Supply Co Ltd - 905-795-1262
385 Admiral Boulevard , Mississauga , ON L5T 2M8
Computerized & Laser Engraving Equip. Sublimation Supplies, Plastics, Metals Sign
Holders, Key Tags, Badges, etc… more
Category : Engraving Equipment & Supplies, Imprinting, Lasers
Map & Directions www.9057951262.yp.ca Save Share Add to Facebook
Skyburt
LinkBack URL
About LinkBacks
