Results 1 to 3 of 3
Thread: Machining a part that is larger than the bed
    May 2008
    Hi All
    I know this is probably on the site somewhere, but I couldn't find the right combination of words in the search to find it.
    I need to machine a 9 foot arc on a router with an 8 foot bed. How do I do it fixturing-wise, The software will let me split the part into sections, I just need a fool-proof way to move and re-set the part on the table.
    Dropout
    Aug 2007
    What I do is pin everything with wooden dowell pins. Spoilboard to machine then blank to the spoilboard. I have to do stair stringers that are 18 to 22 feet long and I only have a 14 foot table. So I have to slide the work down to get it all. Sometimes I have to tab the part to the blank or use an onion skin of about 1/32 thickness then run through the wide belt sander to remove the part. If you have software and you can draw then it is easy to relocate parts to finish them. Every situation is different and the same method will not always work.
    We all live in Tents! Some live in content others live in discontent.
    Aug 2007
    Depending on the width of your Machine you might be able to go corner to corner to get your 9 feet.
  1. Replies: 32
    Last Post: 09-04-2009, 02:54 AM
  2. Machining Multiple of the same part
    By Hellbringer in forum Benchtop Machines
    Last Post: 02-18-2008, 05:21 PM
  3. Machining my part with out cutting everything
    By desktoprouters in forum Solidworks
    Last Post: 02-14-2007, 03:06 PM
  4. Help on procedure for machining this part
    By turboboy in forum General Metalwork Discussion
    Last Post: 12-18-2006, 07:50 AM
  5. Machining both sides of a part?
    By itsme in forum General Metalwork Discussion
    Last Post: 01-03-2006, 10:40 AM
