Results 1 to 3 of 3
Thread: Tool life-Baltic Birch and Maple
    Oct 2011
    united states
    What would the tool life difference be for Baltic Birch and maple? Both thin material-1/8" to 1/4".
    The bit I just purchased is from Precise Bits, it is a 1/16" dia. 2 flute up cut for 1/8" collet. I plan on also trying a down cut, though I don't think it will mater as I am using both sides of the wood when finished.
    I want to do a small production run, thus I am interested in knowing if there would be a difference in using the BB ply or Maple.
    Thanks in advance.
    Dec 2008
    If you care about the edge finish on both top & bottom you may want to consider using a "compression" bit, which is both up-cut & down-cut. I dont think PreciseBit makes them, but I would advise calling Ron to be sure.
    Also, I have had VERY good results ordering PreciseBit products through Jeff Birt (Soigeneris - 573-647-9294). His prices are as good (or better) as going direct to PreciseBit, and his service is flawless.
    TW
    TDA
    TDA is offline
    Oct 2007
    In our tests the tool life difference is up to 20%. However, you may have more of a issue with the quality of of the ply and/or the glue. As an example we had some very expensive ply made for the steel rule die industry. It's glue was so bad on cutters that it had visibly cut a notch in our tools after a few thousand inches.
    As far as cut quality you should get a better cut with a upcut tool. If you are running the proper feeds and speeds you should have a clean cut on both sides.
    Let me know if there is anything I can help with.
    John Torrez
    Think & Tinker / PreciseBits
  1. Newbie- Baltic Birch destroys bits?
    By BoucherPK in forum WoodWorking
    Last Post: 05-17-2011, 10:21 AM
  2. baltic birch questions about chipping
    By groomden in forum DIY CNC Router Table Machines
    Last Post: 04-15-2009, 06:31 PM
  3. Baltic Birch ply + MDF build, which material for which part
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 06-25-2008, 07:21 AM
  4. trouble cutting Baltic Birch
    By carguy327 in forum WoodWorking
    Last Post: 06-13-2006, 01:22 AM
  5. Cutting Baltic Birch with CNC router..which bit?
    Last Post: 03-17-2006, 09:08 AM
