| Wood Lathes / Mills Discuss Wood Lathes / Mills here! |
| Multi-pass incrementing X Hello, Is it possible to increment X on a lathe so that you could have a defined profile and cut off a little at a time cutting back and forth with the Z? Is this a macro function? Kind of like the G77 except a profile, not a line... |
| yes it is possible..do it all the time on my lathe..easy if you have a cam program..if you d'ont have a cam program,you can use a series of g77 to remove the maximum material around your profile then do a finishing pass on your profile alone which has been converted to G codes with a program like dxf2gcode..hope this helps...
__________________ Andy |
Thanks for your reply. What cam program do you use? All the G77 exampes I find are with a straight line. I will need to experiment.... |
| Need Help!- Each pass different than the previous | gage1049 | DIY-CNC Router Table Machines | 4 | 10-22-2008 04:47 AM |
| Need Help!- cut depth per pass | christ371 | Dolphin CADCAM | 3 | 07-19-2008 10:14 PM |
| Multi pass cutting | sykic | Laser Engraving & Cutting Machines | 3 | 12-30-2007 08:52 AM |
| Heidenhain pass | inioxos | General CNC (Mill and Lathe) Control Software (NC) | 0 | 12-09-2007 01:00 PM |
| Can I run axes at different ipm on the same pass? | yorttroy | DIY-CNC Router Table Machines | 5 | 01-04-2006 01:34 PM |
