Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Wood Lathes / Mills
Wood Lathes / Mills Discuss Wood Lathes / Mills here!
Old 07-30-2009, 08:06 AM
Dman65 is on a distinguished road
Router or Lathe
I have been reading and working on a design for a router table and I have plans to convert a Harbor Freight mini lathe to CNC.
Last night I was looking to see what would be involved to CNC convert a wood lathe and now I am not sure what the best approach is. Is it better to take a wood lathe and then create a two axis system to move a cutting tool up and down the length of the item being turned and then move the tool toward and away or is it better to create a three axis system where on axis turns the piece a certain amount and then the other two axes move a router along the length and in and out. Or is there something totally different that I should be looking into?
Thanks for the help.
Old 07-30-2009, 09:06 AM
ger21's Avatar
Really depends on what you want to do. If you drive the spindle with a stepper or servo, you can set it up to work both ways. Either continuously spin it, or rotate to any position you'd like.
4-axis diy router/lathe skyten Open Source CNC Machine Designs 7 08-05-2008 01:52 PM
gear motor for router lathe Blaise Wood Lathes / Mills 5 01-28-2008 09:20 AM
A Small Lathe Router Clockwork Open Source CNC Machine Designs 4 12-27-2007 10:46 AM
Combination 4 Axis router Lathe wjfiles DIY-CNC Router Table Machines 3 04-16-2007 07:08 PM
CNC Router Lathe wjfiles DIY-CNC Router Table Machines 2 10-03-2006 07:34 AM
