Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Wood Lathes / Mills
Wood Lathes / Mills Discuss Wood Lathes / Mills here!
Old 04-21-2009, 12:53 PM
Raykomo is on a distinguished road
Air Pressure Regulator?
Can a bad air pressure regulator ruin a motor for a Standard Router Milling CNC?
Old 04-23-2009, 02:51 PM
MarkT is on a distinguished road
Bad is the operative term here. I have ran into situations where the FRL unit was allowing unusual amounts of water to pass through, overtime rusting internal components of the router. Depending on the initial quality of the router, fluctuations in air pressure could potentially cause issues with tool retention and the drawbar.
Hope this helps!
Mark T.
www.cnccustomservices.com
Need Help!- Electronic pressure regulator 4-20mA? DennisCNC General Electronics Discussion 7 11-03-2008 01:57 PM
Pressure regulator for oil Smackre Mechanical Calculations/Engineering Design 4 06-27-2008 01:21 PM
12V Regulator Max Input... Degrom General Electronics Discussion 16 11-23-2007 09:43 PM
12V regulator N4NV General Electronics Discussion 6 03-16-2007 10:28 PM
PS Regulator freezer General Electronics Discussion 8 02-13-2004 10:48 AM
