Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Wood Lathes / Mills
Wood Lathes / Mills Discuss Wood Lathes / Mills here!
Old 10-09-2008, 02:04 AM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Question Add Wood Lathe to a Mill ?
Has anyone mounted a wood lathe on a mill table for turning?
Only the X and Y would be used.
You could use the router as a tool but a carbide bit mounted in a holder and afixed to the Z would probally be better.
Would the Lathe portion of Mach 3 work this way?
Just an idea.
Old 12-27-2008, 08:54 PM
pescado_loco is on a distinguished road
Hello,
My friend & I just bought a 4860 Shop Sabre. I am working on mounting a mini lathe with an extension on it. I am building brackets so the lathe can lay 90 deg. from upright to fit under the gantry. We are running WinCNC so I don't know about using Mach Lathe. However, in correspondence with Art, he suggested that it would be easier to use Mach Mill when I was working on automating my big wood lathe. I canceled that project. Eventually, we will put a 4th axis on the Shop Sabre to make 3d carved table legs.
cnc wood lathe?? dlh422 CNC Machining Centers 23 06-23-2010 05:39 PM
cnc wood lathe eloid DIY-CNC Router Table Machines 1 10-08-2007 02:15 PM
welcome to the wood lathe forum CNCadmin Wood Lathes / Mills 5 04-29-2007 06:01 PM
CNC Wood Lathe Bucky WoodWorking 6 03-09-2006 02:22 AM
Phenix cnc wood lathe help. Carver DIY-CNC Router Table Machines 3 09-30-2003 04:00 PM
