Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Wood Lathes / Mills
Wood Lathes / Mills Discuss Wood Lathes / Mills here!
Old 09-28-2008, 12:14 AM
Boilermakr is on a distinguished road
Which lower cost benchtop lathe?
I'm looking for a cast iron benchtop wood lather that I can eventually convert to CNC. Right now I'm considering the Grizzly G0624 and the PSI TCLPROVS Turncrafter Pro VS. Amazon covers the shipping on the PSI and the Grizzly is about $290 delivered. I don't have the room for a self-standing unit and have the space for a benchtop unit on my long workbench. I have a 1/2HP inverter-duty TEFC motor and 1/2HP VFD, so the VS isn't a requirement and can be accomplished with better control via my motor and VFD. I'd like at least a 10" swing for future use, but my main use will be turning smaller pieces under 6" diameter and 12" length for audio DIY projects such as speaker building and small amplifier feet. The main use and reason for CNC will be turning aftermarket wood parts for custom headphones and knobs for amps.
Any recommendations for one or the other or a model I've missed for under $500 that can be converted to CNC in the future?
Boilermaker
Old 11-30-2008, 04:24 AM
Zumba is on a distinguished road
The Jet is a favorite of many. I used to own one before my buddy borrowed it permanently.
Old 12-02-2008, 06:47 PM
MarshMan is on a distinguished road
I would go with a Jet before what's mentioned. I have two and both get worked hard, never a problem. Rikon is an excellant choice. The Rikon does have a much better tailstock than any mentioned here. The Jet would be 2nd in this regard.
Old 12-15-2008, 10:45 AM
Norm Smith is on a distinguished road
Have a look at the General Mini. Excellent lathe.
Norm
Old 07-27-2009, 11:53 AM
chinamachine's Avatar
chinamachine is on a distinguished road
you can see our website: http://sinotek.en.alibaba.com, you will find many mini lathes you are interested.
DIY benchtop lathe project dfro Vertical Mill, Lathe Project Log 97 09-26-2011 12:41 PM
A benchtop cnc lathe build S_J_H Vertical Mill, Lathe Project Log 291 06-10-2011 02:02 AM
80/20 benchtop lathe build LeeWay Vertical Mill, Lathe Project Log 72 07-25-2010 10:58 AM
Benchtop CNC mini lathe frank02189 Mini Lathe 14 08-29-2006 08:03 PM
Lower cost machinable foam sheets? vaneeck1 General Material Machining Solutions 7 03-14-2006 08:03 PM
