Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Wood Lathes / Mills
Wood Lathes / Mills Discuss Wood Lathes / Mills here!
Old 09-20-2008, 09:26 AM
fraserneville is on a distinguished road
First posting
Just to stop the header from telling me I've never posted and I should!
I've made Tom McWire's Desk Top Mill (on the Instructables website) and am now learning more about CNC and CAD/CAM
Software is Mach 3, which I have found is easy to use and it provides more as I learn more.
My little machine is accurate enough to make fins, spacers and other bits for model rocketry and model aircraft.
At the moment I am trying to transition from 2D to 3D but cannot get DesignCAD to make 3D polygons that are recognised by MeshCAM (the only 3D CAM program I can reasonably afford.
Cheers
Nev
Old 09-20-2008, 10:01 AM
ger21's Avatar
Try Alibre Xpress, it's free, and can export .stl's that will work with MeshCAM.
I haven't used DesignCAD in a long time, so can't really help you. Can you post a sample .dxf that I can look at. I might be able to find a workaround for you. Also, you might want to ask on the MeshCAM forum if anyone is using DesignCAD, and how they are doing it if they are.
How Do I?- Posting george1668 Forum Questions or Problems 12 03-12-2008 02:13 PM
About posting? Netjams DIY-CNC Router Table Machines 4 04-12-2006 08:55 PM
RFQ Posting LFJ Employment Opportunity 4 08-13-2005 04:31 PM
Posting RFQ CNCadmin RFQ (Request for Quote). 0 11-03-2004 11:57 PM
