| Wood Lathes / Mills Discuss Wood Lathes / Mills here! |
| depth of cut question I am routing some bamboo. I have a 30000rpm router and can run at 50IPM. I will be using a 3/16" bit and doing some detail with a 1/16". I have the code in for making passes with a .08" depth cut. Are my cuts shallow enough, or do I need to ease back more? Thanks |
| All of this depends on how you are holding the part. |
| I'd cut deeper with the 3/16 bit. 1/8 or deeper. Depends on the spindle power, machine rigidity, tool type and sharpness.
| spindle power = 600W the part is bolted down to the table 2-flute endmills Last edited by oxford; 08-12-2008 at 11:08 PM. Reason: more info |
| What RPM/Depth of cut? | sp1nm0nkey | General Metal Working Machines | 4 | 04-07-2007 11:45 PM |
| MCX depth cuts question | charper | Mastercam | 7 | 02-06-2007 11:46 PM |
| dumbass question - cutting depth... | fyffe555 | Laser Engraving & Cutting Machines | 1 | 08-27-2006 05:33 PM |
| Npt Depth | ryanduc | General Metalwork Discussion | 5 | 06-23-2005 05:24 PM |
| Another feed rate, cut depth question | nervis1 | General Metal Working Machines | 8 | 02-10-2004 12:56 AM |
